2000 5.4 water& oil mix up
Question for anyone who has an answer. I have a 2000 f-250 with a 5.4 triton. I left for work today, and next thing you know, its shooting oil out of the ratiator resivor(completely full of oil). Well a guy told me that the oil coolant is in the radiator. Replaced radiator. Still coming out. But it's coming out around the oil filter also. I haven't ran it much. I have a feeling there's a hose near the oil cooler(which is right above the filter, found it) and hose is busted and getting oils and water mixed up, however there's no water in the oil from what I can tell. Anyone know anything I dont? That could really help.
on
OIL IN COOLANT
Check your oil cooler. It is located directly above the oil filter and has 2 hoses connected to the cooling system. The oil filter mounts to the cooler. There is usually more oil pressure than coolant pressure--that's probably why you have oil in the coolant and not the other way around. The cooler has probably ruptured internally.
RON
tomdt1
08-09-2011 05:36 PM
