Superduty auto-locking 4X4 hubs - Page 5 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #61
Old 02-11-2005, 11:32 AM
Brad99SD Brad99SD is offline
Brad99SD is starting off with a positive reputation.
Yah not much of an advertisement is it.
I havent changed to warns yet just cause I actually have no complaints with the Ford hubs running them manually. But I'm sure I'll blow one up one of these days. Depends on what you want to do since you can get them cheaper but I just said the heck with it and run them manually. Plus it's kind of cool having 2wd Lo when moving heavy trailers in the summertime too. But if you can't turn your's manually anymore, well. Anyway good luck.
  #62
Old 02-11-2005, 11:40 AM
RKern RKern is offline
RKern is starting off with a positive reputation.
In checking all hub threads I found a couple of address's for other web sites and they show pictures of ball joint removal-which shows pictures of the actual wheel hubs and seals as well as vacum lines. Also there was a web site address in one of these threads that showed someone cleaning his ford esof hub.
  #63
Old 02-22-2005, 11:19 PM
I still have a vacum problem with my heater controls as they are staying on defrost regardless of what the heater control selector is pointed to. I need assistance in locating the problem.
  #64
Old 02-23-2005, 12:04 AM
7pt3 7pt3 is offline
7pt3 is starting off with a positive reputation.
Quote:
Yours is doing the exact same as mine, no heater when the **** is in 4x4, but switch it back to 2WD and you're okay, right?
If so, you're right, it's a vacuum leak somewhere in the hub system, but I for one am tired of fiddling with the esof hubs, they are apparently just not worth fixing.
Since I've accepted having to lock the hubs manually, my next step is to just pull the vacuum line running to the hubs, and plug it off. I lose the auto-engage (that doesn't work anyway!) but I preserve the vacuum I need for the heater controls.
Not the "right" way to fix it, but I think it's the most realistic.
Robert
  #65
Old 02-23-2005, 12:20 AM
bdcrecy bdcrecy is offline
bdcrecy is starting off with a positive reputation.
Thumbs up Never had a problem...
I have an '03 FX4 w/65K.
Never had a problem w/ESOF. I use my 4X4 regularly on the farm...
I would say you should use your 4X4 regularly (offroad, of course)to keep the system working properly...
  #66
Old 02-23-2005, 12:48 AM
Good advice, but I've had my truck only four months. The damage was already done by the time I got it, I'm just trying to work with what I've got.
Robert
  #67
Old 02-23-2005, 12:54 AM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
30 percent don't work off the lot.
  #68
Old 02-23-2005, 08:05 AM
TI3VOMY3H TI3VOMY3H is offline
TI3VOMY3H is starting off with a positive reputation.
Quote:
92% of statistics are made up on the spot.
If/when I get a new Ford I am thinking of the Manual Hubs. Any concerns with those, hard to lock/unlock etc? Or are warns still the way to go?
  #69
Old 02-23-2005, 08:31 AM
my heater control stays on deforst regardless of the 4wd select **** inside the truck. I am putting warn hubs on and that fixs the 4wd, one of my hubs would not turn unless I used pliers or I would not have changed to warns. But ALAS I STILL HAVE A PROBLEM AS MY HEATER BLOWS OUT THE DEFROST REGARDLESS OF THE HEATER CONTROL LEVER'S POSITION(AC VENT FLOOR) IF MY HEATER IS ON IT ONLY BLOWS OUT THE DEFORST.
  #70
Old 02-23-2005, 08:55 AM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
Robert
I think the answer to both of these could be the vacuum solenoid has failed.
The ESOF system uses a high vacuum level generated by the vacuum solenoid, which is located on the fenderwell beside the battery to engage the locking hubs and a lower level to unlock them. In each case after the initial vacuum is pulled the hubs hold in the proper mode. A complete rundown of the locking hub system is: Vacuum signals are supplied to the locking hubs by system components, including GEM, wiring harness, solenoid, vacuum harness and vacuum seals.
  #71
Old 02-23-2005, 11:17 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
ESOF is simple - reading Ford's description of it doesn't help explain it though
Every So Often it Fails - (just made that up).
My hubs are sticking now, with only 17K miles and 2.5 years of ownership on it. Time to lube them.
To the guy with the defrost problem on ALL ESOF settings, you have a vacuum leak before the ESOF system, where the heater box ties into it. Because of that, sounds like the hubs won't work either...
art k.
  #72
Old 02-23-2005, 11:44 AM
Most of the time it's the hubs, Just plug the red vacume line right at the vacume selonoid behind the battery. I just put some silocone on a bolt around the same size and plugged it and walla, my heater controlles work again in 4wd. I really like still having shift on the fly but just have to lock my hubs in ahead of time. May bug some people but doesn't bother me so much. Yes, it sort of defeats the purpose of ESOF but I'd rather not keep replacing hub assy. every 50K from living in wisconsin with the salt and crap on the roads(hard on the seals). good luck guys.
  #73
Old 02-23-2005, 01:48 PM
F250Wheels F250Wheels is offline
F250Wheels is starting off with a positive reputation.
I have an 04 with ESOF no proplems at 30000 miles. Is the auto lock in the hub or is it part of the manual operator thats monted on the end of the hub?
  #74
Old 02-23-2005, 02:06 PM
In the hub....Sometimes part of the manual operator behind the wheel thats the problem. LOL
  #75
Old 02-23-2005, 02:28 PM
Big Orn's Avatar
There's a line of comedians down at the unemployment office, Dick, and you're trying to be funny.
Auto Lock Front Hub Question Baatzy 1999 - 2003 7.3L Power Stroke Diesel 28 01-23-2015 10:55 AM
? on auto/locking hubs jjlrrw 1999 to 2016 Super Duty 8 11-13-2014 10:10 AM
front hubs dhag911 6.0L Power Stroke Diesel 14 12-12-2013 04:00 AM
4x4 hub auto or auto-lock, CrzHelm Excursion - King of SUVs 4 11-13-2010 10:29 PM
'93 Ford F-150 4WD Hub Question. . . logan 1987 - 1996 F150 & Larger F-Series Trucks 13 11-26-1999 11:41 AM
Tags
4wheel, auto, drive, duty, f250, ford, hub, hubs, leak, lock, lockers, manual, super, superduty, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
