Where to find bumper pad?
Old 01-11-2005, 08:01 PM
Mustang5086's Avatar
Mustang5086
Mustang5086 is offline
Does anyone know of a place to find a used or cheap bumper/step pad. I bought a used prainted rear bumper to replace the DMI rear bumper on my truck, but it didn't come with a bumper pad. Also, I'm looking for a set of stock bumper brackets. There's no good junkyards around here to find this stuff, and the trucks not worth buying the parts new as it is just a beater truck.
Old 01-12-2005, 09:04 AM
crockpot's Avatar
crockpot
crockpot is offline
Make your own step pad out of an old rubber mud flap or a
welcome" mat. The heavier (thicker) the better. If you use weather strip adhesive to hold it down scuff up the rubber with a cup type wire wheel in your electric drill. Wash & scrub away any dirt on the bumper, thoroughly dry and then final wipe with rubbing alcohol before applying adhesive to the metal. Put a heavy weight on the rubber mat while the adhesive sets up.
For bumper brackets you might be able to have 3/8 or 7/16" thick strap steel bent to correct shape by someone you know that does a little welding in his garage.
Try salvage yards in nearby towns first.
Old 01-12-2005, 06:42 PM
Mustang5086
That's my problem, there are no good salvage yards anywhere close. If it comes down to it I'll end up making the brackets myself, it's just that I never can find the time to get stuff like that done.
Old 01-12-2005, 08:19 PM
SoCalDesertRider's Avatar
SoCalDesertRider
SoCalDesertRider is offline
I painted some rubber truckbed liner goop (like Rhinoliner) on the top of the rear bumper on my truck. It works good, nice to have a non-slip surface to step on, especially when it's wet out. Only bad thing is that bumper is chrome and even though I scuffed it up with a wire wheel before I painted the goop on, it's still flaking off. If your bumper is painted, it should work fine though. They sell the goop at most autoparts stores.
Old 01-12-2005, 08:58 PM
NeoCowboy's Avatar
NeoCowboy
NeoCowboy is offline
Broncograveyard has new ones for $25 if I'm right about what you are looking for. I would rather have ones I made myself anyways but I know what you mean about not having the time.
Old 01-13-2005, 06:19 AM
Mustang5086
Thanks for the idea! I had never thought about using the bedliner stuff on it.
Yep, Broncograveyard has the brackets I need. Thanks for the help in finding a cheap set!
RideDiesel88
09-10-2013 02:21 PM
SuperDad
12-18-2012 04:47 PM
ATX F250
6.4L Power Stroke Diesel
04-03-2012 06:35 AM
Jamerian
06-15-2011 10:35 PM
68F250CS
11-02-2005 05:48 AM
Quick Reply: Where to find bumper pad?
