Heavy window fogging, Steam from vents ??
I've got a 85 F-150 4x2 302 EFI and lately I've noticed my windows are fogging up quite a bit(not so in the past) primarily when I use my heater. I've tried anti-fog stuff with no luck. the other morning when I started the truck I noticed steam or something (I dont think it was smoke?) coming out of the floor vent. I dont notice any antifreeze leaks on the ground but seem to smell it inside the truck sometimes. I had someone replace the motor last summer(could this be heater hoses???) Any ideas?
Thank you kindly.
Thank you kindly.
this preety much means you have a leak in your heater box. likely it's time to replace your heater core. you could bypass it temporarilly with a piece of pipe uner the hood, but it's getting cold... Replace it before it ruptures and you get hot coolant everywhere.
had this happen on several cars in the past, once (the first time) i waited, and taking a right turn ended up with a bunch of 200 degree water all over my ankle and foot, dont' do this to yourself!
Could you use one more "I agree", because I'm about to give you one too? Definately sounds like your heater core has a leak. Should be an easy fix, not too hard. I would fix it though instead of rigging it to bypass it. They are pretty affordable and it's a job you can do yourself. Good luck!
-Ry
-If it aint broke, fix it till it is...
1985 F-150 302 4X4
Dana 44 TTB / 9 inch
4.56:1 Front/True-Trac
4.56:1 Rear/Detroit Locker
C-6 Tranny, NP208 Transfer
6 inch Skyjacker Class II lift
35 X 12.50 BFGoods AT's
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6674&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=8776&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6675&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6703&.jpg
-Ry
1985 F-150 302 4X4
89F250_7.5
09-13-2015 12:01 PM
AK Outlaw
05-07-2011 03:19 AM
Spydycarnge
11-17-2009 10:40 AM
SlickWiSlick
16
11-05-2009 07:10 AM
