1978 Ford Bus With 330hd V8
I bought a 1978 Ford BUS with the 330 HD V8 ENGINE, and its running too rough to pass smog. I want to check a few things, but I don't have any info on this engine. I know it is an FT block, but not much else other than that. In particular I need to know the dwell angle and what a good compression test results would be.
Thanks,
Earl-Dale
Thanks,
Earl-Dale
That is a low compression industrial engine - built to perform within specifications but mostly to last. I would not be surprised if you will have to put leaner jets in the carb to pass smog - back then gas was cheap and work engines ran rich to help keep the exhaust valves cool.
btw, the Ford shop manule I bought for my 72 included all the FT engine specs.
tylstruck
51
05-27-2023 04:55 AM
akaFrankCastle
16
03-08-2016 04:51 PM
wcasey
04-09-2015 11:25 PM
EDMCCLOUGHLOCH
1947 and Older Ford Trucks
08-12-2005 07:11 PM
