302 oil pump drive shaft
I have a 85 ford f-150. It has a rebuilt 302 with about 6000 miles on it. It was given to me and I was told it will not start because the distributor kept backing out. The problem is that they did not install the clamp. Beyond that I found out that there is a shaft that runs from the distributor to the oil pump. Question is when I remove the distributor should I be able to see the shaft because i do not see one? Also, I am supposed to see it and i do not would it have dropped into the oil pan or could it have seized the motor?
balingwire
13
04-19-2017 12:01 AM
redbayredneck
01-05-2016 08:01 PM
annaleigh
04-23-2015 03:14 PM
Traderjoe28
09-30-2003 02:04 PM
