Odometer Reset
Odometer Reset
I have a decent gauge cluster set from the '49 Panel that I am parting out. The cluster is very clean for its age. I took it apart to clean out the dust and could see that the speedometer is in very good condition.
I'd like to reset the odometer to all zero's. It was at 93,500 before I disassembled it. I got 4 out of 6 zero's at one time, but then couldn't get the last two. I don't remember how I did it. I was just playing with it and happened to get 4 zeros reset.
Does anyone know how to reset the odometer to zero's? Is there a way to do this?
Thanks, Ilya
Thanks, Ilya
I recently did the same thing on my '58 speedometer. I know they're years apart, but it looks to be constructed in the same way the '58 speedo is.
There's a really easy way to roll it back to zero, I just can't figure out how to put it into words. It involves those metal spacers that have sections sticking up. You have to rotate all of those (except the one by the number you're trying to roll) and then roll the number. Then you move to the next one, rotate the spacers that aren't by the number, then roll the number.
I KNOW how ridiculous this is to read. It's even more difficult to write. If you just "fiddle" with it you'll see how it works. The spacers play a big part. Don't be nervous to rotate them. I think they have some sort of "unlocking" mechanism and that's why they're there. One at a time though. It only takes about 5 minutes.
Good luck.
TC
Good luck.
TC
I did it to my 51 a couple months ago. I had a little trouble with it, but after studying it for a while and spraying it with WD40 I figured it out. You have to sit and look at it, and remember it starts with the tenths, and goes up till it advances enough to move the next cog, and then the next. You have to bring it back down the same way even though its out of the housing. Start at the highest and work back. I do remember it took me a while to get it done.
Originally Posted by 51PanelMan
I did it. I reset it to all zero's. However, I was able to do it by starting from the right side and working to the left. Is there a difference??
Ilya
Ilya
Originally Posted by snipa
I reset mine a few months ago also when I redid the speedometer.
problem is that I cant get it to line evenly with the window it sits in
Here's how my reset odometer looks like. It's set back into the grooves and the holes as needed. I was careful in not moving the tenth digit because then i'd have to reset it to all zero's again.
I think that the 0's line up pretty good.
Now it's on to restoring the rest of the cluster.
Ilya
Ilya
51PanelMan
86
05-06-2015 06:24 PM
51PanelMan
21
10-04-2010 11:44 PM
es2rider
32
05-04-2010 09:58 PM
51PanelMan
24
04-14-2005 11:46 PM
