Chapter Leader Forum??? - Ford Truck Enthusiasts Forums
Old 01-10-2005, 09:23 PM
heavnbound's Avatar
heavnbound heavnbound is offline
heavnbound is starting off with a positive reputation.
Now I know that I have been up too long and my eyes are crossing on their own, but what happened to the Chapter Leader Forum???
Old 01-10-2005, 09:41 PM
Fordlover55's Avatar
Fordlover55 Fordlover55 is offline
Still kicking!!
Fordlover55 has much to be proud ofFordlover55 has much to be proud ofFordlover55 has much to be proud ofFordlover55 has much to be proud ofFordlover55 has much to be proud ofFordlover55 has much to be proud ofFordlover55 has much to be proud ofFordlover55 has much to be proud of
I see it. It's right above this forum.
Old 01-10-2005, 10:28 PM
F2504x4's Avatar
F2504x4 F2504x4 is offline
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
I can't see it either , Dennis said there might be some teakin & tunin going on .
Old 01-10-2005, 11:04 PM
Still kicking!!
LOL!! This is funny. I got my permissions all worked out and now you guys can't see it.
I'm sure it will all be worked out soon enough. Be patient, my friends. Just say it's all Dicks fault and go grab yer little voo doo dolls of him and a handfull of pins and then ........ what the HECK am I saying!!!!
fordborn's Avatar
fordborn fordborn is offline
fordborn has a great reputation on FTE.fordborn has a great reputation on FTE.fordborn has a great reputation on FTE.fordborn has a great reputation on FTE.
I no longer can see it either. Also received an email saying there was a reply in the forum and when I click on it I am told that I do not have the proper rights to see it.
Old 01-10-2005, 11:35 PM
heavnbound's Avatar
Quote:
Whew! I thought there had been a mutiny and I had been overthrown! At least it's not just me!
Old 01-11-2005, 12:43 AM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
Same thing happened to me. Worked fine yesterday, wonder whats up.
Old 01-11-2005, 01:07 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
I can still see it too
nyah nyah
Ken and Eric and Dennis have been doing some more work and ironing out some little problems so be patient and I'm sure it will get fixed soon.
Old 01-11-2005, 01:47 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
I just checked the permissions and they were OK. This seems to be a different problem than the Mod's access to the CL forum. Heavnbound's account shows the same signs of corruption that are shown in three moderator's accounts that can't see the mod forum. I will check some files:
Other corrupt files:
f=2504by497
mustange70
fordborn
-All three of you so far.
The consistent sign of corruption I have seen is that the following item has no Y/N setting in the file:
"Pop up a Notification Box When a Private Message is Received"
Just for grins... Can you guys check your User CP and see if a setting for that option shows? Then see if you can set it. After you have set it, test your access to the CL forum. When I have set the option in the past from the Admin panel it has made no difference. Let me know what you find out.
Old 01-11-2005, 01:58 AM
heavnbound's Avatar
Ok I went to my CP and tried to find this option. I looked at the bottom of Send a Private Message where some Options are shown but that wasn't one of them. I don't get a pop up message about PM.s - I get an email saying I have one.
Old 01-11-2005, 02:27 AM
mustange70's Avatar
I have that option Eric, it was set to recieve a pop up noticed, turned it off just now and nothing changed, i will try changing it again and see if anything happens.
Tried it and nothing changed.
Old 01-11-2005, 03:06 AM
heavnbound's Avatar
Torque1st,
I found the Option you were talking about. It was checked. I cleared the check, logged out of FTE and came back in. Nothing changed - still can't see the CL Forum.
Ok now something else weird. I went back to the Option and found it was checked again! Bizarre!
Old 01-11-2005, 03:26 AM
Torque1st's Avatar
Posting Legend
Thanks guys!
Both accounts now show that option checked in the Admin panel. When I set the option on other accounts thru the Admin panel it did not help either but I could always hope...
Sorry it did not help. It does show as a the only consistent indicator or abnormality that I have found for Ken. Unfortunately there is another bug in the software from a recent security patch that may be causing more damage than it is preventing. It all may be related. I am kind of dead in the water for permissions upgrades, new mods, etc until this is solved. I don't want to be messing up files any more than they are.
One interesting side note, Fordlover1951's file shows the same missing setting but he is able to access the mod forum. So the corruption indicator is not 100%. I can't remember if it was set the last time I looked at it because I check soooo many of those things everyday...
Maybe you guys can get together and see if you can remember the last time you changed anything in your User CP. Maybe you all recently accessed some feature????? -Grabbing at straws.
Old 01-11-2005, 07:49 AM
fordborn's Avatar
Same here I made the changes and it didn't work. I haven't made changes to my options for months that I can remember.
Old 01-11-2005, 10:15 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I had noticed the same problem, I was waiting until it was mentioned to say anything, figured it was an update, and be patient, ot it would come out all the same... well, it came out!
NJ Chapter Leader Nominations/Volunteers tjc transport New Jersey Chapter 33 10-19-2009 06:36 PM
Steping down as chapter leader rbloodhound Louisiana Chapter 0 04-29-2009 06:59 PM
Chapter Leaders.Please..... F2504x4 General Chapter Discussion 7 03-15-2006 10:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
