86 302 efi to 351w marine engine?
Hi, i have a 86 f250 with a 302 efi. My grandpa runs a boat yard, and he aquired a newly rebuilt 351w with high performance heads , intake , cam and pistons.
My concerns are:
going from efi to carb, would i need a new gas tank/ fuel system?
it has a "marine cam", would this be any good for a truck?
would my exhaust bolt up?
what would i do with the efi wireing harness? would the things like oil pressure and temp guages hook up right?
anything else i should concider?
My concerns are:
A lot of the marine engines run reverse rotation. That's the reason for the "marine cam".
Going from EFI to Carb will require a fuel regulator to bring the fuel pressure down to 5 to 7 psi. Or you will have to remove the tank mounted fuel pump, get a tank pickup out of an earlier carb'd truck and use a mechanical engine mounted fuel pump.
86stepsideF150
02-14-2009 04:00 PM
SPRPRBGT
02-13-2007 08:40 AM
maineoscarfish
11-28-2006 04:04 PM
