transfer case lubricant - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Old 01-10-2005, 05:20 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
I'll be changing the oil in my transfer case (95 Bronco, Borg-Warner 13-56) soon, and wonder what would be the best lubricant? Mercon, Mercon V, or some kind of concoction like 1 pint of synthetic 75W-90 and ATF. The fluid recommended by Ford is Mercon multi-purpose ATF XT-2-QDX. Would the difference between Mercon and Mercon V be significant in this case?
TIA
Old 01-10-2005, 05:48 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
I prefer synthetics. I would use either Mercon V or Mobil synthetic ATF. You don't state how many miles are on the Bronco but since it's a 95 I assume it has quite a few. A transfer case isn't subjected to heat like an engine or transmission so it probably doesn't matter, Mercron or Mercon V. I would stay away from mixing with gear lube.
cmlind cmlind is offline
cmlind is starting off with a positive reputation.
Probably not, but I would stick to mercon. Do not use any gear oil. Since it takes only 2 quarts, synthetic would not be real expensive change, but I am not convinced that a transfer case needs synthetic. I used Valvoline durablend in mine and 30k later it started having problems jumping out of 4wd. Probably not the oils fault. I don't think a transfer case is very hard on oil and under normal 2wd service doesn't have that many internals in motion. I would recommend staying with Mercon.
Old 01-10-2005, 11:32 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
I use Mobil 1 synthetic ATF in a 87 F250 4x4 plow truck at work. It only takes a couple quarts so I thought 'what the heck, why not?' Only cost me $20!
-Matt
Old 01-10-2005, 11:43 PM
peppy's Avatar
peppy peppy is offline
peppy is starting off with a positive reputation.
For what its worth........Valvoline MaxLife ATF in my '91 1356.
Old 01-11-2005, 01:53 AM
I've read somewhere that Mercon V is more slippery than plain Mercon, and while that's no good in a tranny designed for Mercon, in the case of a transfer case there are no clutches and bands where a precise amount of friction is needed for proper functioning.
Old 01-16-2005, 06:42 AM
MScotty MScotty is offline
MScotty is starting off with a positive reputation.
A friend of mine who had a repair garage had a truck (Ford) come in with a blown transfer case. The customer had bought it used and had said before he bought it the transfer case had been rebuilt.
Well after removal my friend openned up the case, it was empty, with no sign of fluid ever being in it.
But inside he found there is a small pick up pump driven off the main shaft, which must help in keeping the chain and bearings lubed as apposed to the chain just being bathed
in the lube.
So a synthetic I think would be the best choice, I've changed it in my Bronco II and Explorer. I also put synthetic ATF in my T-Birds manual trans, and it made a big difference in the winter.
Old 01-16-2005, 01:50 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Full synthetic Mercon is your best bet. Brands like Mobil1 and Royal Purple ATF fit the bill nicely. Ford even makes a 100% synthetic Mercon (part # XT-2-QSM) which you can order. These are all top notch fluids that far exceed Ford's specs and requirements for your particular application. No need to get into the Mercon V thing.
?transfer case fluid for 2005 4x4 Expedition buckarooboy Expedition & Navigator 3 01-11-2015 12:24 PM
transfer case fluid type? 96mark8 1999 to 2016 Super Duty 3 09-28-2013 02:17 PM
Mobil 1 Synthetic ATF bpounds 6.0L Power Stroke Diesel 5 04-10-2010 08:52 PM
ATF/Mercon, Mercon V "Brand" Info. (?) bodyelite Oil & Lubrication 19 06-28-2008 01:15 AM
New TSB On Transmission Fluid Beachbumcook Excursion - King of SUVs 4 08-29-2006 11:39 AM
Tags
06, 90, blown, borg, case, f150, fluid, ford, lubricant, lubricants, mercon, proper, transfer, warner, xt2qsm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
