Vibrating F250
Vibrating F250
Hey folks for the last 3 months my truck has been vibrating profusely when not in gear. Usually it vibrates at its worst when iding around 1000 RPM. But when I put it in gear the vibration all but goes away. I doesn't really vibrate while driving, just a little pulsating humm every so often. A mechanic told me he thought it could be the harmonic balancer, but I was wondering if it was the timing.
If you have one of those 2 piece balancers with the rubber ring in between, the outer half may have slipped, throwing you motor out of balance. It will behave differently at different rpms, just like an unbalanced driveshaft. If you try to set your timing to it, things will likely get worse.
Barkin 40s
04-17-2011 11:47 AM
