E4OD OD off light blinks at highway speeds
just got back from a road trip with my 95 PS with E4OD. On the way there yesterday about 80 miles into the trip the OD off light starting blinking. I stopped and checked fluid level, temp, and both were fine. Noticed that the transmission was shifting very hard also. Light only blinked while speeds were above 40 - 50 mph. On the way back today it was fine. Anyone else experinced this??? No clue what happened. Thanks Josh
RocknXJ is exactly right. I would head to Auto Zone or the Stealership and get the codes pulled. I would def. not drive to much more. I have heard guys take simple problems and turn them into transmission replacements or rebuilds by driving while that light is flashing. I hope it is a cheap and easy fix for you but don't let it go.
Scanned it at work today, no codes available from transmission, just solenoid status, and other non helpful info. Its been fine ever since so I think the TSB i found is right. It said a number of things causes that, such as torque slippage, internal leakage, low line pressure, etc. I think Ill run it till it blows up then swap in a 5 stick. Thanks for the advice.
TX92F150
08-08-2013 08:32 PM
finitetime
05-07-2011 01:39 PM
cornbinder
24
10-25-2010 12:15 AM
