Coil Pack Order - Ford Truck Enthusiasts Forums
Coil Pack Order
Old 01-09-2005, 07:14 PM
Thaxon Thaxon is offline
Thaxon is starting off with a positive reputation.
Coil Pack Order
I have 2001 Ranger Edge, 3.0L non FFV, 2 wheel drive, manual tranny, with 60K miles, barely broken in. Awesome truck, I love it. It's my 2nd ranger. My first was a 94 I bought with 13K, traded in back 2000 with 198K and zero problems.
Hoping someone can clarify a question for me here, and from what I've seen on this site I'm sure you guys can. The coil order on my 3.0L goes 4, 6, then 5, correct? I printed it up off of the firing order page, but just wanted to make sure.
Also, since I'm not the most mechanically proficient guy out there, why isn't just 4, 5, 6 for the order? Just curious.
Thanks for any help you guys can give.
Old 01-09-2005, 08:13 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
The graphic below does indeed accurately depict the coilpack ID numbers:
Not sure why the coilpack is arranged like it is, I've often wondered the same thing.
Old 01-09-2005, 08:27 PM
Thanks for the reply. Back to drawing board then, must have done something wrong trying to tune it up because it's running real shaky and the check engine light popped on. Any suggestions?
Old 01-09-2005, 08:50 PM
Rockledge's Avatar
If things were OK before the tuneup, check that you didn't knock off any hoses or electrical connectors while working around inside the engine compartment. And make sure the gaps on the plugs are correct, sometime the electrodes bang into something while the plugs are being installed and that affects the gap.
Also, if you don't have a scanner, but do have an Autozone or other national name brand auto parts store in your area, you can drop by and have them read the codes, most will do it for free. Get the code(s) and then you will know for sure what direction to go.
Old 01-09-2005, 10:45 PM
Thanks for the tip, I know it's gotta be something simple. The plugs were pre-gapped at .046 and my manual said .042-0.46, but I'll double check. Friend of mine has a diagnostic tool that will work, so I'll go that route too. Thanks for all the help.
04 ford ranger edge 3.0 2wd stribling99 3.0L V6 2 12-21-2015 10:49 AM
Another Rough Idle-04' escape paschman2000 Escape & Escape Hybrid 5 10-26-2011 08:23 AM
Hard to Find 225/70R14 Tires sstrunk Ranger & B-Series 6 08-10-2010 06:01 AM
Ranger 3.0 vs 4.0 BigBlockGuru Ranger & B-Series 46 01-29-2004 10:37 PM
03 ranger edge 4.0 supercab and disabling the governor stampz2k1 Ranger & B-Series 4 05-21-2003 06:12 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
00, 2000, 2001, 30l, 40, coil, coilpack, diagram, f150, firing, ford, order, pack, ranger, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
