Gutted the interior
#32
#33
#34
#35
I'll have to check out the foil. I am thinking of something that has the bubbles. What you use depends on what you are trying to control. I like the peel and seal as a first coat. It adds much density to the sheetmetal. Takes care of audio vibes, road rocks etc. No insulation value though. I don't honestly know what I really need for insulation, in Iowa, with a carpet that is well padded in the first place.
#36
here's my one and a half cents worth. for cutting holes in the carpet i use a soldering gun. it burns a hole as wide as you like and also seals the threads at the same time from runnig. also, i have a 56 and have used the home depot wrap for water heaters. a roll about 16 inches wide is about 10-15 bucks and will cover the whole floor. use duct tape for the seams. put the carpet over it and you cant hear any "popping". the end
#37
The "bubble wrap" stuff won't actually pop, it's more like heavy poly honeycomb than sealed bubbles so it doesn't go flat. We use it to make tire covers to hold in the heat in our tires when racing in cool weather. sometimes we've run over it, flatten them down and packed stiuff on top of them when traveling, toss a jackstand on top them to keep them from blowing away in the wind, etc and it hasn't hurt it, tough stuff.
#38
imlowr2,
B&M makes a "truck" version of their Megashifter. It's just like the refular version but it has an auxillaru adjustable bracket under it that can raise it up a few inches. It also comes with a taller plastic surround piece. Take a look at their website or Summit, Jegs, etc. I installed one in my 49 and I like it.
I purchased my on Ebay for a bit cheaper than the typical vendors sell them for.
I can't wait to see how the carpeting comes out. I'm looking to do the same thing to my truck pretty soon
Good luck
Bobby
Good luck
Bobby
#40
Ed,
May want to ask around a bit before you purchase the carpet kit. I found a guy to do a custom carpet job on mine any color I want and he will go all the way up the firewall for $150, and to top it off he is going to do the install in my garage. Will update my gallery when it happens. Right now he is finishing up a black vinyl roll and tuck on a stock bench seat I found and I am anxiously waiting to get it. I got my insulation from Lowes cost me about 60$ to do the entire cab roof and all, made a tremendous difference with heat and road noise. Joe
#41
redneck_davis
53
09-09-2019 01:14 PM
dspickle
1997-2006 Expedition & Navigator
09-02-2015 11:38 PM
MavSprint
120
06-10-2014 05:46 PM
