5.4 life expectancy - Page 3 - Ford Truck Enthusiasts Forums
5.4 life expectancy
  #31
Old 08-27-2010, 01:58 PM
braveheartE350 braveheartE350 is offline
braveheartE350 is starting off with a positive reputation.
E350
243,000 and still going.
  #32
Old 08-28-2010, 11:15 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
My 01 F250 5.4L auto have 185K miles
Have lot trouble when I bought 2 months ago.
It been sit for 3 years with 181k. Never start or moved.
I replaced 4 tires, grease front end, spark plugs, air filter, and change oil that it.
It been get 15 mpg mostly but rare is 16 but never drive on highway long enough to get actual mpg.
I would say I able to see 300K miles on this truck.
  #33
Old 09-02-2010, 11:02 PM
RustyTrustyF150's Avatar
RustyTrustyF150 RustyTrustyF150 is offline
RustyTrustyF150 is starting off with a positive reputation.
I am looking at my first 5.4 in a 03 fX4 with 167,000 miles on . The truck body is like new so I think I am going to give it a try .
  #34
Old 09-03-2010, 02:29 AM
Flat_Ford Flat_Ford is offline
Flat_Ford is starting off with a positive reputation.
now i wish i'd bought the F-150 instead of my car...it was at a car lot so idk the previous condition..i test drove it and the engine was strong but the trans had a shudder..it had about 150k on it...and a couple weeks later i found out he had to replace the trans...i instead bout an 01 cavalier Z24 i've given it a good run around it had 136k on it and i'm now at 152k in just over a year...i get junk for gas milage but you gotta pay for speed.....anyway my point is that newer technology has made engines more reliable...all i've replaced on my car is the plastic thermostat housing... i read an article that said in manufacturing the new mail jeeps they are built and equipped to run over 300k with just regular maintenance....sorry for the tread jack...just a little input.
  #35
Old 11-02-2010, 06:22 PM
Katmandu's Avatar
Katmandu Katmandu is offline
Katmandu is starting off with a positive reputation.
Thumbs up
I just read a story where a Expiditer racked up 1,271,xxx miles (YES! That is MILLION) and still running on his 97 E250 Cargo Van!
Check out his website....
Click here to read about this MILLION MILE VAN
  #36
Old 11-05-2010, 01:01 PM
kevin32764 kevin32764 is offline
kevin32764 is starting off with a positive reputation.
Quote:
Originally Posted by JonC View Post
I'd be curious to know which grade of oil the 5.4's noted in this thread with high miles used. 5W20, 5W30, 10W30, etcJon
Mine 2000 Ford Regular cab SD 4x4 and 180,000 miles. I use 10w30.
  #37
Old 04-03-2013, 12:13 AM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
Quote:
Originally Posted by nobrandx View Post
I just turned in 2 98 expeditions with over 246,000 miles that's using rerefined oil, the only thing that went bad was 1 alternator, these were U.S. Military vehicles utilized for going to missile fields but the 5.4 is an excellent engine, and would have no problem buying a high mileage one
my 97 exped 5.4 just turned 167K and still going strong....great vehicles.
  #38
Old 04-04-2013, 09:37 AM
1979 Ford's Avatar
1979 Ford 1979 Ford is online now
1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold
I have a 97 Expedition with 231,000 miles on it. It runs fairly decent. I bought it for $500, I've put about $800 into repairs and have a decent 4x4 that seems to have a fairl amount of life left. If not, I am not out much and could drop another engine it and keep on trucking. The body is great shape, the interior needs a few pieces and a good cleaning.
  #39
Old 04-04-2013, 10:33 AM
drey04's Avatar
drey04 drey04 is offline
drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.
224,000 and counting on my truck in my sig.... take care of that 5.4 and it'll take care of you.
  #40
Old 04-04-2013, 01:43 PM
Had 99 Expedition with 157K back in March 3 right now it had 163K miles. I feel it will able hit 200-300K miles if it not rot out.
City average 15 and Highway 18.7 with couple of idle/stop. Should get more than that when I replace brake and tires.
MAJOR ISSUES that you need check out.
Air filter housing is piece of JUNK. It doesn't ever fit air filter correct it let dust go inside engine. It got me 3 mins try fit correct way before I latch it.
Vacuum hose/elbows rot off
Defect thermostat cause MAJOR sludge inside engine. It was 178oF. New motorcraft theromstat bring up 190oF and gas mileage went up 5 mpg.
Coolant you SUPPOSED to change every 5 years. Thank god it didn't eat engine yet. I going keep flush coolant every year for that reason.
Keep SALT OFF engine and coolant lines so try wash salt off but avoid spray direct at coil packs or you will have miss.
  #41
Old 04-05-2013, 12:49 PM
wkbrdtx wkbrdtx is offline
wkbrdtx is starting off with a positive reputation.
200K
200K on my 2003 Expedition 5.4L
I have no money to buy another so I have to keep this one going. Oil and filter every 5K. Coolant and trans flush and new fuel filter every 50 K.
New plugs, cops and serpentine belt every 100K. Major problem was limited slip differential stopped slipping when turning from a complete stop. Ford rebuilt it. The clutch pack and friction modifiers had to be corrected and had to have a new ring gear. That was about $2K (of course it was out of warranty). It has been fine ever since. The vacuum hoses do get brittle and Ford has some neat little plastic vacum line pieces that can be discarded and bypassed with a plain old vacuum line circled around to make the bend. Ford designed a nice plastic cover to go over the intake and make the engine compartment look pretty. Snapping it on and off interferes with some of the vacuum lines so I have removed it and it is in the attic.
  #42
Old 04-22-2013, 01:07 PM
fordiesel69 fordiesel69 is offline
fordiesel69 is starting off with a positive reputation.
Modular engines die for 2 reasons:
-Oil starvation: They can use a little oil when they age, and if run low, say goodbye. The higher the oil consumption just means more attention to keeing it full. Doesn;t mean tear it down for a rebuid, it will keep going.
-Lack of coolant maint. When you grab the hydrometer and it says you are protected down to -32 degrees and thats it for a coolant test.....say goodbye. 30-50k in 2-3 yrs is good for green. 75-100k in 4-5 yrs is good for motorcraft gold / g-05. Any other coolant, or any other interval is a death sentence on the cooling system / head gaskets.
If you measure electrolysis, and find it present in your cooling system, it is a matter of time before it attacks the head gaskets or aluminum head itself. It can happen at 130-150k but usually in the 200k it will work its way thru near the thermostat area of the head. Keep the electrolysis out by maintaining coolant change intervals from the start.
  #43
Old 04-23-2013, 07:26 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
^^^ That's quite interesting but where does one find info on doing those tests, needed equipment/tools and so on?
I'm more than guilty of neglecting my cooling system I'm sure!
  #44
Old 05-19-2013, 03:09 PM
stephen.osborne1's Avatar
stephen.osborne1 stephen.osborne1 is offline
stephen.osborne1 is gaining momentum as a positive member of FTE.stephen.osborne1 is gaining momentum as a positive member of FTE.
My wife's 2000 (My old truck, and still hunting rig) has 163,xxx on it and runs great. It did pop a plug about 30,000 miles ago, but I think it was my bad, as I had recently given it a tune up and used Bosch plugs... (I have since learned to use only the Motorcraft or Autolite platinums). It has a small oil leak near the intake manifold somewhere, so I have to keep an eye on the oil, usually adding a quart between changes at 4,000 miles.
I never replaced all the cops at once, instead replacing one at a time, as they go bad. I have replaced 6 as of now.
I put an Auburn limited slip in the rear ab out 7 years ago, and while I had it all apart, I went ahead and installed a new ring and pinion. It didn't need to be replaced, but I figured I might as well do it so it would last that much longer.
  #45
Old 05-20-2013, 04:10 PM
F250CCowner F250CCowner is offline
F250CCowner is gaining momentum as a positive member of FTE.
These engines are built for longevity rather then all out performance. Just look at the equivalent GM LS engines. Those make great power stock and respond better power wise to modifications then the modular motors do but how many of those engines do you hear going way over 200K? Not many. These mod engines are by far the best for longevity and for being workhorses. That is why you see them in taxi's, police interceptors, fleet trucks, vans and the service industry. A properly maintained mod motor should go over 300K if you have an owner that didn't neglect or abuse it daily. Not to mention they get decent mileage for being a V8. My 2002 Mustang GT with an auto gets 21-23 MPG routinely driving up and down the Cajon pass. These are good, solid engines.
'07 F150, 5.4l, what to expect? Rico47635 2004 - 2008 F150 5 02-10-2016 09:00 PM
When to replace fuel pump & best brand? 80s Trucker Expedition & Navigator 12 01-20-2015 01:53 AM
2010 5.4 maintenence & upgrades J tothe Roc 2009 - 2014 F150 1 01-18-2015 04:25 PM
2003 F250 5.4 4x4 questions malibulxi 1999 to 2016 Super Duty 7 07-02-2014 07:58 AM
99-03 5.4l triton mpg powerstroker100 1999 to 2016 Super Duty 15 12-23-2011 01:43 PM
Tags
1997, 54, 54l, average, engine, expectancy, f150, ford, life, lifespan, mileage, realistic, span, truck, truct
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
