Electric Fuel Pumps In Dual Tanks - Ford Truck Enthusiasts Forums
Old 01-08-2005, 08:30 PM
D. DeBoer's Avatar
D. DeBoer D. DeBoer is offline
D. DeBoer is starting off with a positive reputation.
Hello All,
Do the fuel pumps in dual tanks run simultaneously or when a specific tank is selected by the tank selector switch? Thank You in advance for your input.
Old 01-08-2005, 11:23 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
If you have the selector switched to the front tank the intank pump in the front tank will run as well as the one on the frame rail. If you are on the rear tank then you have the rear intank pump and frame rail pump working.
-Matt
Old 01-09-2005, 09:01 AM
D. DeBoer's Avatar
I should have said that this is on a 85' F250 7.5L 460. This is carburated so there is only intank fuel pumps, but I believe that only one should be working at a time. Could it either be a bad dash fuel selector switch or the fuel pump relay switch?
Thank You Very Much.
Old 01-09-2005, 12:14 PM
Beast12's Avatar
What exaclty is the problem you are having? Are they both running at the same time when the truck is running? You can check this better by getting a piece of garden hose about 4 feet long. Stick it down the filler tube and listen. Let me know if I can be more help.
-Matt
Old 01-09-2005, 12:16 PM
D. DeBoer's Avatar
both pumps are running
Old 01-09-2005, 12:53 PM
Beast12's Avatar
Well then my guess would be selector switch. Maybe try switching it back and forth realy fast to see if it will "unstick" itself temporarily until you can get a new one?
-Matt
Old 01-09-2005, 01:00 PM
D. DeBoer's Avatar
Thank You very much for your time and advice. I really do appreciate it.
Old 01-09-2005, 05:54 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
For what it is worth, I have had nothing but trouble with fuel pumps etc. on my 86 F250 4x4. I put two new pumps in when the gauge quit. They have never worked right since. The rear tank pumps 5 PSI, the front pumps 1-3 sometimes. So I added a Carter Elect. Pump mounted on the frame with a Pres. Reg. ON/OFF Switch. Now I have little problem. I keep thinking I'm going to put about a 75 gal tank in the bed, and just remove all factory crap that has to do with fuel. Just run the Carter & Pres. Reg. 3/8" feed line and a 5/16" return line and the heck with all this trouble & cost. I think that your problem is in the switch over valve, That I believe is where some of my problems exist, and if I replace that at I think about $150 then I'll have over $500 in two pumps a valve and miscellanous hoses and stuff and if you add up the Carter pump, pres. reg, & Pres. gauge 6 bills is closer. Heck I could of bought a bed tank & gauge unit and saved alot of money. My point is this system has been junk and still is. I was working for a Ford Dealer in 84 and we worked on this system all the time. This must of been one of CHEVYS BETTER IDEAS, THAT FORD JUST COULDN'T SAY NO TO.
94 f150 4x4 dual tanks merbno Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 10-14-2014 05:36 PM
F250 Dual Tank Removal danlee 1987 - 1996 F150 & Larger F-Series Trucks 1 12-16-2009 10:09 PM
Fuel pump question on dual tanks wifes65 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 07-24-2008 05:39 PM
Electric Fuel Pumps In Dual Tanks D. DeBoer Fuel Injection, Carburetion & Fuel System 3 01-09-2005 07:40 AM
what next 86 f250 superflytee Fuel Injection, Carburetion & Fuel System 2 05-11-2004 10:54 PM
Tags
duel, electric, fuel, pump, tanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
