Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 01-08-2005, 12:06 PM
matthoward matthoward is offline
Garage is empty, add now
matthoward is starting off with a positive reputation.
90mm maf on 00 lightning
i am thinking about purchasing a 90mm maf for my 2000 lightning, does anyone know if i have to change anything like the inlet boot or anything else to install this on my truck, i just ordered a diablo sport predator so i can tune every thing in together. thanks for any help.
  #2 (permalink)
Old 01-08-2005, 01:50 PM
yysenhimer yysenhimer is offline
yysenhimer is starting off with a positive reputation.
Everything else should remain the same
__________________
'05 F250PSD CC
  #3 (permalink)
Old 01-14-2005, 03:19 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
I also upgraded my stock 80mm MAF to a 90mm MAF on my '99 L. Along with the FMS 90mm MAF, I also purchased a new inlet boot so I don't know if the one sized for your 80mm MAF will work.
Remember though, unless your stock airbox has been changed to an '01 and up airbox, or you changed to an aftermarket setup, the opening in your stock airbox going to your MAF will still only be 80mm.
All trucks are different, but you shouldn't need to tune the truck after upgrading to the 90mm. I was told by my local dealership I wouldn't have to, and the majority consensus of what I read at the different Lightning forums stated I wouldn't have to either. I was told the computer will read the 90 and compensate accordingly. Everyone was right. I didn't have to tune or reflash my computer. It took to the 90mm MAF like a duck takes to water, with ZERO problems. No pinging (detonation), idle problems, or MPG issues.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #4 (permalink)
Old 01-25-2005, 10:28 PM
WendyC WendyC is offline
WendyC is starting off with a positive reputation.
I have a mustang and am going to a 90mm lightning maf and need the part from the filter to the maf. Is that what you meant by 'inlet boot'? Where do you find one the right size?
  #5 (permalink)
Old 02-03-2005, 06:05 PM
rdy2rac rdy2rac is offline
rdy2rac is starting off with a positive reputation.
for a 90mm upgrade as long as you dont have more boost than stock(ie pulleys) than the stock computer will compensate for the meter. it will lean it out though. you'll need the 90mm the boot and a airbox desinged for the 90mm entry like was mentioned above.if you have any kind of pulley or supercharger upgrade (ported blower or kb/whipple) than i would hope you had already did a chip. the tune for the predator needs to be adjusted for this upgrade as well.
Tags
2000, 2002, 80mm, 90, 90mm, airbox, boot, expedition, ford, lightning, maf, mm, pingin, stock, tune
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
