Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-07-2005, 06:18 PM
JQ JQ is offline
Garage is empty, add now
JQ is starting off with a positive reputation.
477 in a '92 F250?
Is it possible to have a factory installed 477 in a '92 f250? I can't find any ref material on this subject.
  #2 (permalink)
Old 01-07-2005, 10:05 PM
Birken Vogt Birken Vogt is offline
Birken Vogt is starting off with a positive reputation.
The 401-477-534 Super Duty motors were available in medium and heavy trucks from the 50s until the early 80s and are truck-size motors that will not go in a pickup. A 92 F250 could have had these engine choices I think:
300 I6
302 V8 (maybe)
351 V8
460 V8
7.3L IDI NA Diesel
  #3 (permalink)
Old 01-08-2005, 12:11 AM
whalerron whalerron is offline
whalerron is starting off with a positive reputation.
The 302 was available in an F250. I never did understand why the truck could be ordered with a 300-6 but not with a 302. The 300 has lots of low end torque but it's dead at highway speeds. The 302 has alot more power at highway speeds than the 300 does.
  #4 (permalink)
Old 01-09-2005, 01:18 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
patfogle DaPocky
In a 3/4 ton the 302 can't keep up. The 300 was a better engine and would take a little longer to get to highwya speed, but would maintain it better.
__________________
1996 F150 Regular cab, SWB, 4.9. 5speed.
- Life is like a roller coaster, Live for the ups.
- Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
- If you have to ask "Will this hurt?" do not proceed!
  #5 (permalink)
Old 01-13-2005, 11:29 PM
ML1983 ML1983 is offline
ML1983 is starting off with a positive reputation.
The 401-477-534 engine family were no longer produced after about 1983.
I'm not totally sure, but I believe in '92 you could have:
(4.9L) 300 I-6
(5.8L) 351 V-8
(7.5L) 460 V-8
(7.3L) 444 V-8 Diesel
I'm pretty sure the 302 was only available in the F-150....not positive though.
  #6 (permalink)
Old 01-13-2005, 11:37 PM
pfogle's Avatar
patfogle DaPocky
Nope, in 92 the 302 was offered in the 3/4 tons too..... In the F250 HD the standard engine was a 351w, with the option of the 460, or 7.3 diesel. In the F350 the same applied.... I think the 300 was also offered in the F250....
__________________
  #7 (permalink)
Old 01-14-2005, 03:11 PM
Momudder720's Avatar
Momudder720 Momudder720 is offline
Momudder720 is starting off with a positive reputation.
Hey Birken, how are those engines on power? Just curious...looking for a replacement for the 351 in my bronco...
__________________
02 Ranger 4.0, 5-speed, 4x4 FX4
72 Bronco, 351W, C6, 4.10's, tube buggy
79 Ford with 93 Chevy body, 460, C6
  #8 (permalink)
Old 01-31-2005, 10:04 PM
zwinstead's Avatar
zwinstead zwinstead is offline
1995 Ford F-350
My Garage
zwinstead is starting off with a positive reputation.
You would not want a 401-477-534 in your Bronco. First of all it would crush the front end second of all it would only run about 55 mph. They are HUGE large truck engines. Low speed high torque, low horsepower.
__________________
Zac
77 F-150 472, C-6, 3:50 / 77 F-250 408, C-6, 4:10
95 F-350 7.3L, EC, DRW, 4:10 / 87 Ranger 2.9L, Driver
  #9 (permalink)
Old 02-06-2005, 10:54 PM
98f1504x4ohio 98f1504x4ohio is offline
98f1504x4ohio is starting off with a positive reputation.
and about 2 MPG pulling 30K LBS
__________________
Mine:
98 F150 4X4 XLT Ext. Cab Short bed
4.6 4R70W MSOF 3.55LS 16X8 eagle 589's wrapped in 285/75/16 Dayton Timberline MT's
79 Jeep CJ 7, In pieces, but I got it for $850
  #10 (permalink)
Old 02-15-2005, 03:50 PM
GreekGod GreekGod is offline
GreekGod is starting off with a positive reputation.
534-yes Yes Yes!...DO IT!
Give him a break! He DOES want a 534 in a Bronco! It could be the PERFECT engine for ANY street-driven Ford! Sure they ARE a LITTLE heavy and big, BUT, with a torch, welder, some steel, maybe an air ride suspention anyone could be "Liv'in LARGE" [w/ Zoomie headers and no fenders of course]. Seriously though, the 401-477-534 was an AWESOME engine series in it's day. Around here they came in a lot of school-busses and dump-trucks. Sodium-cooled exhaust valves, oil-cooler built in the block, 100,000 mile warranty from Ford. The dump-trucks had [GM] Allison 5-speed "Trans-Matic" manual-shift auto-trans. When I used to deliver them to county road-commision garages here in Michigan you definately wanted to use the F250 PU instead of the F100! And don't forget to hit the brakes and slide it to the front of the bed before taking off! The assemblies came w/a 13.5" clutch and bell-housing. I think they weighed about 1700 POUNDS.
Quote:
  #11 (permalink)
Old 02-16-2005, 09:34 AM
Correction: Now that I think about it, the 534 on a skid w/ bellhousing & clutch was more like 1300-1400 lbs.
  #12 (permalink)
Old 05-24-2005, 08:35 PM
10MPG's Avatar
10MPG 10MPG is offline
10MPG is starting off with a positive reputation.
302's weren't available in 3/4 & up after '86.Only 1/2 ton.
__________________
'75 F100 Explorer-300/3spd, '85 F150 4x4-300/4spd
'93 F150 XL-300/5spd, '92 F350 4x4-460/5spd
'75 Maverick-200/3spd, '72 Comet-5.0/C4
And an old '78 Jeep Wagoneer
  #13 (permalink)
Old 06-03-2005, 09:38 PM
the_webers_inc the_webers_inc is offline
A mostly quiet ^
the_webers_inc is gaining momentum as a positive member of FTE.
Quote:
I know for a fact that you could get the 5.0 (302) in an F-250 at least up to 1991 and maybe later than that. My proof: My buddy's first truck was a F-250 Reg cab long box 4x4 5.0 5spd (M5OD). All stock truck. I know that it was the Mazda 5spd too, I seen it when he had it out when putting a clutch in that truck.
T. J.
P. S. ~ the 401-477-534 engine series must of been an awsome beast in there day -- but puting one in a F-Series, even a F-350 sounds about like putting a T444E (7.3 Power Stroke) in a Ranger. But what the heck -- if the will to do it is there -- Go for it!
  #14 (permalink)
Old 06-05-2005, 04:04 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a good reputation on FTE.82F100SWB has a good reputation on FTE.
The F250 LD's got the 302, in trucks over 8500# GVWR, it wasn't offered, only 300, 351W, 460, and whatever diesel was avalable at the time.
__________________
96 F350 Crew Psd/5 speed,/4x4... $600 special
96 F250 XLT PSD/5 speed/4x4... Freebie!
92 W250 LE, 4x4/CTD/G360/D60/D70U
86 F250 HD 4x4, 6.9/T19/broken D44 TTB junk/10.25.
8? F100 4x4 Mild 460/T19 D60/welded 10.25/44 Boggers,
It's not what you BUY, It's what you BUILD
  #15 (permalink)
Old 06-06-2005, 07:52 PM
A mostly quiet ^
Quote:
Exactly.
Even if it is light duty F-250 its still a 3/4 ton truck
Tags
351, 351wcom, 477, 72, 92, duty, f150, f250, ford, headers, maverick, options, super, wwwheaders, zoomie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
