Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader: archtaan
  #1 (permalink)
Old 01-07-2005, 05:50 PM
MonsterBroncoKid's Avatar
MonsterBroncoKid MonsterBroncoKid is offline
Garage is empty, add now
MonsterBroncoKid is starting off with a positive reputation.
My truck is tryin to Kill Me
okay so im drivin down the road one day and i had to swirve suddenly to avoid being t-boned by a big rig. no biggie, but when i did it my battery fell over on the motor during this process the truck just started shaking violently back and fourth and flung the top of my bronco off of the truck. now ive strapped the battery down and no more battery problems, but for some reason now the truck at random will violently shake as before even though the the battery isnt on the motor. now ive check the balljoints and all steering linkage shocks and such and evrything is fine.
does anyone know what or have an idea what the hell is causing this? i needf to kinow before the truck kills me!!!!!!!!
__________________
You call it rust. I call it character
Garrett Crance
ex 1979 Bronco
1984 bronco
Click To View The Current VA Time
  #2 (permalink)
Old 01-10-2005, 09:55 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
1987 Ford F-250
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
Did any battery juice get on anything? Did the battery short out on the motor? Are you sure its not the motor missing badly? Where did the battery hit?
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4
VIRGINIA CHAPTER
Virginia Chapter Website
  #3 (permalink)
Old 01-16-2005, 07:00 PM
Unhappy
nope no battery juice on anything, yes it did short out a lil bit, it landed on the altenator and stalled the belts briefly, and yes the motor was, but no longer is out of time or missing.
__________________
Garrett Crance
ex 1979 Bronco
1984 bronco
  #4 (permalink)
Old 01-16-2005, 09:18 PM
1987 Ford F-250
I don't know, this is a weird problem. If the there was a short on the motor, I would check for loose or burned wiring, melted connections, maybe even have the computer system checked for any shorts. I betcha a nickel that your problem is electrical. My cousin had me drive her car to see what was causing it to jump really bad. I told her it might be the clutch going. It felt like it would slip, then grab, it was that violent. Turned out to be a fuel delivery issue, some shorted out relays.
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4
VIRGINIA CHAPTER
  #5 (permalink)
Old 02-14-2005, 06:20 PM
73-79owner 73-79owner is offline
73-79owner is starting off with a positive reputation.
bad shake
my dads truck did the shake thing real bad, it was his bushings on the radius arms that were worn out. Replaced them and never did it again.
  #6 (permalink)
Old 02-15-2005, 05:22 PM
thanks man i appreciate it but i already got rid of the truck and that wasnt the problem though. refer to the post Tragedy strikes
__________________
Garrett Crance
ex 1979 Bronco
1984 bronco
Tags
battery, crance, fell, garrett, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
