Raising the front bumper on my 84 after body lift? - Ford Truck Enthusiasts Forums
Old 01-07-2005, 01:05 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
I installed a 2.5 inch Rough Country suspension lift on my 84 F150 4x4. I want to put an additional 2 inches of body lift on it as well. I want to raise my front bumper when I do this, none of the body lift kits I have seen for this truck have a bumper raising kit available. I was thinking of cutting my frame horns off and raising them 2 inches and welding them in place, then box it back in using 3/16" flat stock. How did you guys raise your bumpers? I want something that looks good and still retains the same structural integrity. Also do I have to do anything with my steering shaft for a body lift? Any other necessary modifications to think about? Its a regular cab long box with the 300 six, 4speed, 4x4. Any and all help is appreciated!
Old 01-07-2005, 01:36 PM
MatthewC's Avatar
MatthewC MatthewC is offline
MatthewC is starting off with a positive reputation.
Thats what most people do to raise the front bumper: Cut the frame and weld it higher. I havent seen, or heard of any problems doing this. Im unsure as to its legality. Other have taken the time to have new mounts fabricated to avoid cutting up their frame.
-Matt
Old 01-08-2005, 01:40 AM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
it really wouldn't take any time at all to cut, drill, and weld a set of 1/4" brackets to lift it up the height you want!
-cutts-
Old 01-08-2005, 06:43 AM
Pkupman82's Avatar
I think cutting my frame horns and raising would be easier and I can do a cleaner job and I think it would be stronger. I also think I am going to add an additional crossmember in the front. I am going to fill all the holes in the frame for more strength. To add to that I am going to have a buddy of mine, who is a fabricater by trade build me a 2 inch front receiver for mounting a winch to match the receiver I have in the back. Is there anything I will need to do to the steering shaft? I know I am okay on the clutch because I have a hydraulic clutch... no linkage to mess with. My transmission and transfer case shift levers are plenty long, I don't think I will have to worry about them. I plan on using aluminum diamond plate to fill the gap under the tailgate, or get a drop style rear bumper. Any other ideas fellas? Thanx for your help!
Old 01-08-2005, 09:46 PM
78f3504x4's Avatar
78f3504x4 78f3504x4 is offline
78f3504x4 is starting off with a positive reputation.
Do what ever it takes to raise the bumper. Some people leave them down and fill the gaps with diamond plate. This looks terrible.
Lift Kits 2001f1505.4 1997 - 2003 F150 19 04-26-2013 01:28 AM
3 inch Body - bumper lift help i-w 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-14-2011 02:53 PM
Need Help Figuring Out What To Do To Raise Front and Get Snow Plow Ready Ruckus 2004 - 2008 F150 32 09-01-2009 04:28 AM
Best way to lift 93 F150?? del1650 Offroad & 4x4 14 02-17-2006 08:32 PM
Body Lift Installation Questions outlawnbfd 1987 - 1996 F150 & Larger F-Series Trucks 5 05-18-2005 06:37 PM
Tags
1979, 1984, body, bronco, bumper, bumperon, bumpers, f150, ford, front, frony, lift, mods, raise, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
