300-6 to small block
Lockley, I don't know what 63 motor mounts look like. I have a 73. It had a 240 which is the same block as a 300 in it when I bought it. I went to a 302 for a short time. The motor stands for the small block were no where near the same as the inline 6. In 63, were there some trucks available with FE's? The reason that I ask, is on a 73 model truck the FE and inline 6 are almost identical. Also, I'm sure there was a 6 cylinder application in 63. Try using those engine stands. Don't worry about messing with the after market stuff, there has got to be some sort of factory stuff that will bolt right in. Check the classifieds. Guys are always pulling out inline 6's for V8's. I bet you could find the 6 cylinder stands for cheap. That FI 300 in a 63 would be super cool. In 63, don't you have it set up to where the engine mount is in the front and then 2 on the bell housing?
I believe that ford started putting 240/300 inliners in in '65 or '66. if I could come up with a complete set of mounts I would use them ,but, all the parts catalogs ( lmc, dennis carpenter, ford obsolete) that I have do not have complete sets of mounts or all the pieces to buy separately. your righ about the 292 mounts that are in it now (1 up front, 2 out back) I may see if i can modify them to work seeing as how the sixes in 63 used the same set up.
poppawoody
01-08-2011 08:03 PM
BMW2
11-23-2002 07:27 PM
