Yamaha, 300 hundred dollars to remove and replace an exhaust manifold lol, I think I'm in the wrong line of work
. I like the header Idea myself, I'm running a set of shorty headers on my truck and the bolts never loosen up.
If you decide to go the header route you should consider doing the install yourself. A few days before removing the stock exhaust manifolds you need to start soaking all the manifold bolts with penetrating oil to ease removal. Quality header gaskets are a must, I'm running Percy's aluminum header gaskets with great results. When I did the install I used a bead of ultra copper around the exhaust ports on both sides of the gaskets and let it tack up for about 15 minutes before bolting the header on. After you get everything back together retorque the header bolts everyday for a week and you'll never have to worry about bolts loosening up
