clicking sound from front drivers side tire???? - Ford Truck Enthusiasts Forums
Old 01-05-2005, 07:04 PM
hopscotch hopscotch is offline
hopscotch is starting off with a positive reputation.
Unhappy clicking sound from front drivers side ????
hello everone i just brought a 1986 ford 250 4x4 while driving it i have noticed a clicking sound coming from the drivers side tire as i speed up so does the sound
not sure where to start looking or fixxing this is my first 4x4 help me please
also where can i get a real repair manual got the haynes but veyy brief. thankyou all
hop
Old 01-05-2005, 09:11 PM
paden's Avatar
paden paden is offline
paden is starting off with a positive reputation.
You might check your spedometer cable. I had one once that clicked when it was cold and it sounded like it was from the left front wheel.
Old 01-05-2005, 11:39 PM
nudgey nudgey is offline
nudgey is starting off with a positive reputation.
sorry to state the obvious, but could it possibly be a screw/nail/stone in the tyre ?
chris
Old 01-06-2005, 11:35 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
aside from the screw/nail/stone it could also be a hubcap if it has them, busted cord in a tire, bearing or hub (less likely)
Old 01-06-2005, 04:40 PM
fixnmyf150 fixnmyf150 is offline
fixnmyf150 is starting off with a positive reputation.
It may also be a loose break caliper.
Old 01-06-2005, 06:40 PM
Lee Lichterman's Avatar
Lee Lichterman Lee Lichterman is offline
Lee Lichterman is starting off with a positive reputation.
FWIW - I have this too and just now figured it out. The brake pads are supposed to have a little clip that holds the pad in place. ( I am not even sure what it is called but I think it is called an "anti-rattle clip". Mine are both gone and my driver's side occasionally makes a racket when I am going slow. It almost sounds like someone is tapping on my wheel lightly with a small ballpeen hammer.
I haven't figured out where I am going to get these to replace them yet. The only reason I knew they were missing was that I have them on my other truck but not this one. The sound had been driving me nuts until I figured it out.
Lee
Old 01-06-2005, 07:08 PM
Talking clicking sound
thanks for your input on the sound i checked for rocks nails and screws found none. looked in the hub caps found nothing. as far as the speedo cable it doesnt work on the dash so maybe :{
i am going to grease up the hubs and do the the ball joints this weekend so we will see thanks
Old 01-06-2005, 07:21 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Clicking? HAS to be u-joints. Check for play/wear. Good luck!
-Matt
Old 01-06-2005, 07:22 PM
paden's Avatar
Quote:
You can eliminate the spedometer cable by just unscrewing it from the side of the transmission, tape up the hole when it is removed. If the cable is broken inside there is probably a bur or twist at the break so every time it twists around the inner piece catches on the outer shell.
A lot of times auto parts stores will have those little brake sound clips in those red bubble card things (same place you find replacement door handles and window handles). If they don't have them there they will usually come in the better brake kits.
Old 01-06-2005, 09:19 PM
Trial and Error Trial and Error is offline
Trial and Error is starting off with a positive reputation.
I had a clicking noise in the front of a 4WD Trooper which was caused by grease drying out or lack of grease in the hubs, allowing for partial disengagement of the gears within the hubs. I had the hubs repacked for a chunk of change and the problem was gone - no replacement parts required.
Old 01-07-2005, 02:58 AM
Quote:
Thanks!!! I will check out that "Help" isle at the auto store tomorrow.
Lee
Old 01-07-2005, 08:01 AM
MRStace84's Avatar
MRStace84 MRStace84 is offline
MRStace84 is starting off with a positive reputation.
If it gets louder when you go around a turn, it's the U-joint in the front axle.
It is the brake clips, it will make a rattle while going down a rough road, but by gentley pressing the brake pedal the rattle will stop.
If your hubs have not been torn down and repacked, then something could be getting dry in there
Old 01-07-2005, 11:57 AM
big hoss 29's Avatar
big hoss 29 big hoss 29 is offline
big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.
Just a thought, but after you hear the clicking, check the position of the locking hub. I had an 83 F-150 4x4 and when I would go down a bumpy road, the drivers side hub would spin to lock. I would get out and spin it back to free, drive for awhile and it would spin back to lock.
When it would do this, it would make a rattling noise, like someone shaking a spray paint can. I changed the hubs out and the problem went away. You might not need to change your hubs out, but you should inspect them at least.
Old 01-07-2005, 05:25 PM
thanks for the tip i am going to change the universels tomorrow andre build the hubs
again thanks for you help
hop
Old 01-07-2005, 07:15 PM
the peppermint the peppermint is offline
the peppermint is starting off with a positive reputation.
my neighbors truck had the hubs taken apart at one time by a previous owner, who did not put them back together correctly it caused a clicking sound because it was trying to lock in
Grinding from the hub kawasaki150hp 2004 - 2008 F150 1 06-07-2016 07:48 PM
1990 f-250 clicking sound. kilo82 1987 - 1996 F150 & Larger F-Series Trucks 2 07-09-2013 08:35 PM
Power Window Clicking Sound Aztrainer 1997 - 2003 F150 12 01-29-2008 08:29 PM
Clicking sound when turning....HELP !!! mikemic Brakes, Steering, Suspension, Tires, & Wheels 2 04-05-2006 10:48 AM
4X4 Clicking Sound on 1997 Ranger?? kds1973 Ranger & B-Series 3 12-17-2004 12:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
