Testing the Wiper Control Module
Old 01-04-2005, 10:31 PM
n2wheelinxjs's Avatar
n2wheelinxjs
n2wheelinxjs is offline
I have replaced the Wiper motor, and the wiper switch assembly and still no wipers, Is there a way to test the WCM? This is on a 1992 F150 4x4. Or any other ideas on what the problem could be? Thanks...Cody
Old 01-05-2005, 07:33 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE
We are happy to have you on board!~
Old 01-05-2005, 07:45 AM
wtroger's Avatar
wtroger
wtroger is offline
The answer is no you replace the module when all other tests pass. Usually when the module is bad you will have high speed but no low or intermitten. Get a copy of the testing procedures you can wire the motor up on the outside and see if will run. Make sure the switch is grounded. That is basically the tests.
Daddyo's garage
1997-2006 Expedition & Navigator
20
12-22-2016 06:38 AM
Grizzly4x4
10-21-2014 02:57 PM
anoxic
08-14-2009 07:44 AM
dcicc50
02-06-2009 04:34 PM
ddbuggins
12-13-2004 07:47 PM
Quick Reply: Testing the Wiper Control Module
