What max. p.s.i. does a typical Ford power steering pump create?
Old 12-05-2002, 09:20 PM
BigJake86's Avatar
BigJake86
BigJake86 is offline
I'm interested in how many psi a Ford powersteering pump can create, at what rpm, and approx. how much power the pump draws. Also, do the pumps have built-in relief valves or are the relief valves in the steering box? I have a few projects in mind that could utilize hydraulic power and I am curious what these power steering pumps are capable of. Thanks, Jake
Old 12-05-2002, 10:31 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
I would recommend against using the Ford pump. These things have an integral reserve, and if you are running a ram of any kind, it will drain this quickly. Also, they do not like being run low on fluid. I would use a pump from a japanese truck, as they use a remote reserve, and you can make it any size you want. They also produce more pressure at a lower rpm. I am rigging one off of my old Isuzu Trooper diesel to fit my 84 F-250, to power a hydraulic winch. Northern tool and equipment also has a wide variety of hydraulic pumps for different app's.
Jared
Old 12-08-2002, 07:46 AM
mshumack's Avatar
mshumack
mshumack is offline
The Ford CII pump (F150-350, Bronco) flows 1.5 gallons/minute at 740 psi. The pressure relief is in the pump and set at 1400 to 1500 psi.
The Ford Saginaw pump (E100-350) flows 1.8 gallons/minute at 620 psi and its relief valve is set at 1350 to 1450 psi.
Old 12-08-2002, 11:48 AM
Jens's Avatar
Jens
Jens is offline
Old 12-08-2002, 02:07 PM
BigJake86's Avatar
BigJake86
Cool, thanks!
Old 12-08-2002, 05:13 PM
electricmaniac2's Avatar
electricmaniac2
electricmaniac2 is offline
I know it would be sacrelige, but I have a serpentine belt driven P/S pump in a 90 G20 that has remote resivoir that might work on something like that.
kweiss
06-08-2021 07:52 AM
ceraboy
1983 - 2012 Ranger & B-Series
06-14-2020 09:24 AM
Ben_E
06-30-2017 11:53 PM
KYSlowhand
11-25-2016 07:39 AM
Justins68ford
07-23-2011 06:36 PM
Quick Reply: What max. p.s.i. does a typical Ford power steering pump create?
