You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What max. p.s.i. does a typical Ford power steering pump create?
I'm interested in how many psi a Ford powersteering pump can create, at what rpm, and approx. how much power the pump draws. Also, do the pumps have built-in relief valves or are the relief valves in the steering box? I have a few projects in mind that could utilize hydraulic power and I am curious what these power steering pumps are capable of. Thanks, Jake
I would recommend against using the Ford pump. These things have an integral reserve, and if you are running a ram of any kind, it will drain this quickly. Also, they do not like being run low on fluid. I would use a pump from a japanese truck, as they use a remote reserve, and you can make it any size you want. They also produce more pressure at a lower rpm. I am rigging one off of my old Isuzu Trooper diesel to fit my 84 F-250, to power a hydraulic winch. Northern tool and equipment also has a wide variety of hydraulic pumps for different app's.
Jared
__________________
Jared
Real trucks have the key on the left FTE Guidelines
I know it would be sacrelige, but I have a serpentine belt driven P/S pump in a 90 G20 that has remote resivoir that might work on something like that.
