1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Track bar bracket info...
Old 01-04-2005, 09:12 PM
Colorado Red's Avatar
Colorado Red
Colorado Red is offline
Is there any difference in the brackets? I have pretty much all my front suspension and steering for my '01 F350 V10, but I need a lifted bracket. I'm giong to about 5" lift...any suggestions, how much should I spend, and does anyone have one for sale?
-Mike
Arvada, CO
Old 01-04-2005, 11:39 PM
Kadukoboy's Avatar
Kadukoboy
Kadukoboy is offline
If I understand your question right....
I think Superlift has one but i'm unsure of the price...I have an 8 inch lift and they replaced the bracket in the the middle if the track bar
Old 01-05-2005, 05:21 AM
Badford's Avatar
Badford
Badford is offline
buy the adj trac bar..................you won't be sorry!! it will help avoid bump steer problems. alittle more money but alot less headache!
Tony
Old 01-05-2005, 07:00 PM
Colorado Red
Now if I get the adjustable track bar, do I need the drop bracket also? (at 5" lift)
Old 01-06-2005, 04:22 AM
Badford's Avatar
Badford
Badford is offline
mine is supposed to extend from stock length to + 6" if you wanna buy a skyjacker bracket for a 2" lift ill sell you mine............
Old 01-06-2005, 09:32 AM
mattsf250's Avatar
mattsf250
mattsf250 is offline
you need a drop bracket, even with a adj trac bar...steering correction needs to be made with a drop pitman arm, and it will interfere with the stock trac bracket....thus, do both of them.
with my 6", the trac bar bracket is massive, and the trac bar slipped right in with zero effort.... my bracket is adjustable, 4 or 6" of lift....after that, you use the 6" spot, and an adjustable trac bar for ~ 8" lift.... at 10", crossover steering, so the pitman arm is less of a problem with trac bar bracket interferance.
i have a 4" drop bracket, and pitman arm as well.... i could be cohersed into lettin em go i bet.....maybe even with my 4" hangers!
Old 01-06-2005, 10:09 PM
Colorado Red
Badford---Thanks for the offer, but I'd like to get at least a 4" drop bracket and then see if the adj. track bar is necessary.
mattsf250--I PM'ed you. I'm interested in the bracket, but already have hangers.
I do already have the pitman arm and swaybar links....its coming together slowly!
cpickner
Colorado Chapter
08-16-2011 09:09 AM
ranger pat
Colorado Chapter
12-28-2007 08:29 PM
johnsjsj
07-19-2007 02:10 PM
rikfish
Colorado Chapter
12-10-2002 07:06 PM
COMT
Colorado Chapter
12-04-2002 11:49 AM
Quick Reply: Track bar bracket info...
