supercharging a 4.6L crown victoria
Hi and welcome to Ford TRUCK Enthusiasts
It's possible. Take a look at http://www.crownvic.net/ubbthreads/index.php
I just did a quick search there and found some info.
Have fun
Have fun
The Marauder as a concept car was supposed to have a super charger but in production it was just a Cobra(detuned?) motor. I think they planned to use a Whipple or Roots type blower.
The 4.6 can be supercharged, Car and Driver did a flog several years ago where they did just that. This probably helped push Ford on the Marauder concept. Unfortunately, I think C&D blew up 2 or three motors getting it right.
I think the Lightning is a 4.6 with supercharger(Roots/Whipple I think). If so, then it can be done commercially and there might be junk yard motors around(I bet at a premium).
The main thing with supercharging stock motors like the 4.6, so I have read, is to be conservative, you don't want to melt things or detonate it to pieces. The chebby group I belong with did a LOT of supercharging(mostly Paxton type, some Roots/whipple and some turbo) experiments with the LT1 and discovered early on that the factory pistons(hypereutectic, I think Ford uses these too) would melt if you got too aggressive with the boost. If you want a lot of power you will need to beef up the innards if you want to live. Stay conservative and you will have plenty of fun for "reasonable" cost.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
Originally Posted by grease monkey
I wonder if you can swap a supercharger out of the new cobra 4.6 liters. If it is a 4.6 I dont see why not.
haynes
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
05-17-2006 01:30 PM
whohears
03-09-2006 03:21 PM
