supercharging a 4.6L crown victoria - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 01-04-2005, 06:23 PM
ownacrownvic ownacrownvic is offline
ownacrownvic is starting off with a positive reputation.
is it possiable to supercharge a crown vic's 4.6 and if so where could i find one for it and not spend a boat load of money all replies are greatly respected
Old 01-05-2005, 07:39 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi and welcome to Ford TRUCK Enthusiasts
It's possible. Take a look at http://www.crownvic.net/ubbthreads/index.php
I just did a quick search there and found some info.
Have fun
Old 01-24-2005, 11:57 PM
hotrodford87's Avatar
hotrodford87 hotrodford87 is offline
hotrodford87 is starting off with a positive reputation.
go to www.CrownVicMuscle.com and www.alternativeauto.com
Good stuff there!
Old 01-30-2005, 02:09 PM
ElvishWarrior21 ElvishWarrior21 is offline
ElvishWarrior21 is starting off with a positive reputation.
Wouldn't such a thing be the Mercury Marauder? Or am I mistaken?
Old 01-30-2005, 02:36 PM
73Fastbackv10's Avatar
73Fastbackv10 73Fastbackv10 is offline
73Fastbackv10 is starting off with a positive reputation.
Vortech makes a kit for it. It requires that the alternator be turned backwards. Looks kind of weird.
Old 01-30-2005, 04:26 PM
TheFrog TheFrog is offline
TheFrog is starting off with a positive reputation.
Isn't that the same engine as the mustang? It was supercharged, check Ford Racing
Old 01-31-2005, 01:47 AM
fbodyfan fbodyfan is offline
fbodyfan is gaining momentum as a positive member of FTE.
Quote:
The Marauder is a de-tuned Cobra motor (4v), but not supercharged. I assume you could do it with any blower made for the 4.6 (lots) but then again I know nothing about Crown Vics.
Old 01-31-2005, 01:35 PM
grease monkey's Avatar
grease monkey grease monkey is offline
grease monkey is starting off with a positive reputation.
I wonder if you can swap a supercharger out of the new cobra 4.6 liters. If it is a 4.6 I dont see why not.
Old 01-31-2005, 01:50 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
The Marauder as a concept car was supposed to have a super charger but in production it was just a Cobra(detuned?) motor. I think they planned to use a Whipple or Roots type blower.
The 4.6 can be supercharged, Car and Driver did a flog several years ago where they did just that. This probably helped push Ford on the Marauder concept. Unfortunately, I think C&D blew up 2 or three motors getting it right.
I think the Lightning is a 4.6 with supercharger(Roots/Whipple I think). If so, then it can be done commercially and there might be junk yard motors around(I bet at a premium).
The main thing with supercharging stock motors like the 4.6, so I have read, is to be conservative, you don't want to melt things or detonate it to pieces. The chebby group I belong with did a LOT of supercharging(mostly Paxton type, some Roots/whipple and some turbo) experiments with the LT1 and discovered early on that the factory pistons(hypereutectic, I think Ford uses these too) would melt if you got too aggressive with the boost. If you want a lot of power you will need to beef up the innards if you want to live. Stay conservative and you will have plenty of fun for "reasonable" cost.
Good Luck,
Jim Henderson
Old 01-31-2005, 03:47 PM
Quote:
The air inlet is on different sides. In Mustangs, the air filter/box/tube is on the passenger side. On Crown Vics, the air filter/box/tube is on the driver side. Not even the throttle bodies will swap without modification to the linkage.
Supercharger for 4.6L Marcus0418 2004 - 2008 F150 5 05-19-2015 06:58 PM
4.6l mod questions BackwoodsF150 2004 - 2008 F150 13 03-03-2011 09:39 PM
Looking to supercharge my 4.6 haynes Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 10 05-17-2006 02:30 PM
2005 4.6L Supercharger? fordmarshall111 2004 - 2008 F150 5 09-11-2005 09:07 PM
4.6 Supercharged Lightning Engine Swap?? rbenlouis Escape & Escape Hybrid 8 12-14-2002 11:26 PM
Tags
2003, 46l, crown, ford, supercharger, vic, victoria
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
