7.3 diesel injector pump turn up - Ford Truck Enthusiasts Forums
Old 01-04-2005, 02:11 PM
dieselhotrodder
Guest
Posts: n/a
i was wondering what the two screws on my 1991 7.3 international that have the caps on them do... the caps are the seals so that no one messes with them.., i want to get it to pour out the smoke.. i also was wodnering if anyone has a turbo system for that? thanks
Old 01-04-2005, 08:02 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
Welcome to FTE. There are a few companies that make turbos. Banks and ATS etc. They are a little pricey though. You can turn the pump up but you should find a way to let in more air and let more out as well (bigger intake and exhaust). I never turned mine up so I can't tell you how or how much. I will leave that to some of the diesel gurus. Good luck with it.
Old 01-04-2005, 09:08 PM
nogo73's Avatar
nogo73 nogo73 is offline
nogo73 is starting off with a positive reputation.
get a pyro first also Just because a diesel blows lots of black smoke doesn't men its fast that unburnt fuel.I recommend driving it around and doing this some where warm(makes the truck easier to start. there in a small home plate on the passenger side of the intake. stick rags under there unbolt the two bolts and the fuel will pour out ok now you have to find the allen head screw by turning over the motor by hand (always disconnect the two wires on the Injector pump) ok sooner or later you find it and the right allen wrench. clockwise turns it up and counter clockwise turns her down. Warning: if you do this without a pyro blow up your motor remeber I told you to get a pyro first. $115 auto meter 2 1/16" that what I bought. Don't go over 1200 degrees (tempeture in the combustion chamber; also aluminum is totally liquid form around 1400 degrees) you will melt the pistons.
Old 01-04-2005, 09:36 PM
nogo73's Avatar
screw puting a turbo it (unless you got $2500 sitting around)right away I recommend you cut out the fish bowl. and do somthing with the exhaust. I straight piped mine first thing for $40 dollars at a local muffler shop(this is the bang for the buck). then later on I put headers on and dual 3" this was nice but I always wondered what a turbo would do.
1994 7.3L IDI TURBO FUEL RETURN LINE ? kjjr20 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-18-2014 05:16 PM
Oil filter cap help. Hotwheelbill 6.0L Power Stroke Diesel 13 12-26-2013 01:02 PM
Proper Radiator Cap terrylamar 1994.5 - 1997 7.3L Power Stroke Diesel 16 09-19-2013 10:26 AM
2001 7.3 blow by ?? jeepster1272 1999 - 2003 7.3L Power Stroke Diesel 2 01-04-2013 05:07 PM
Which O Rings for my injectors 93turbo7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-31-2010 11:10 AM
Tags
1989, 73, 73l, diesel, ford, injection, injector, international, pump, specifications, turn, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
