Heated Seats Timer... Any way to bypass?
I would assume the heaters in the f-150 are the same as a f-350. If so there is no timer.
There are two thermal switches in the seat portion. When the seat is warm enough the switch opens and breaks the circuit. Once cooled enough the circuit closes and the element heats again.
They are different as I've ridden in the Lariat F-350 2005 model year. Those switches are located on the seats and they do stay on, except for the thermal cutout.
The F-150 has a pushbutton located on the dash. It is located right above the ashtray and one for each seat. There are three settings that you get when pushing, they cycle through. High, Low, Off. There are red lights right above the switch indicating the state of the heater. There is a 10 minute timer located somewhere in that circuit that will turn off the heater in the seat. You can repress the button and heat will return. There may be a thermal cutout in the F-150 seats as well, not sure.
It's the 10 minute timer portion of the circuit that I am looking to modify or bypass. Even if you know where I could get a schematic of this circuit would be helpful. 2004 - 2008 F-150 factory heated seats.
90pioneer
6.7L Power Stroke Diesel
11-28-2016 10:46 PM
reamer
03-27-2016 07:11 AM
