2100 2150 difference?
Not a whole lot. One of the major differences I've seen is that 2100's have an air-horn mounted choke pulloff, and 2150's have it mounted behind the choke linkage. 2150's later came equipped with more gadgets like a high speed metering system, a more advanced fuel bowl venting system, and a hot idle compensator.
A 2100 is incredibly simple. You've got a fuel bowl with a float, jets, accelerator pump, venturis...2150 is pretty much the same plumbing. Seems like I've seen kits that read "2100\2150" before.
ojcolina
06-10-2013 02:59 PM
