1978 - 1996 Big Bronco
94 Bronco Speedometer and shift problem
Old 01-04-2005, 08:25 AM
BrentsSF's Avatar
BrentsSF
BrentsSF is offline
Last night I was driving and I lost the speedometer and the
auto transmission began to shift very rough. The truck runs but there is no readout on the speedometer and shifting is a problem.
Old 01-04-2005, 10:42 AM
BrentsSF's Avatar
BrentsSF
BrentsSF is offline
Additional information
I changed out the blown #8 fuse and it immediately blew again. So I have a short somewhere in the wiring, my daughter said she saw a flicker like a spark beneath the glove compartment just as I lost the speedometer, any ideas what
might be causing the short?
Old 01-04-2005, 01:13 PM
newrob1's Avatar
newrob1
newrob1 is offline
Here is a valuable piece of advice I am going to give you. You need to take your rig to a transmission shop or someone with a electronic diagnostic tool for the transmission. The speed sensor in the rear axle of your rig controls 3 things the ABS, the speedo, and the transmission. I just had a custom rear axle, 9", built for my 92, I disconnected the speedsensor thinking it would only affect my ABS, which was ditched, and the speedo. I was right and had no more speedo, what i didn't realize was that sensor also tells the trans when to shift and tells the pump when you are at highway speed so it can go into full lock to pump more fluid. I blew an E40D after 10 miles on the highway and now have installed a C6 instead. A tranny shop can tell you if the speed sensor is working and if the computer is responding to the speed sensors information. Either component could give you the symptoms you are describe. You won't have much problem at low speed but you will do severe damage at highway speed. I'm living proof. Check it out soon!
Old 01-04-2005, 03:08 PM
BrentsSF's Avatar
BrentsSF
BrentsSF is offline
Thanks for the information, I will be sure to avoid damage to the tranny, I onced owned a Taurus, vintage 89 and did three
tranmissions before ditching it. no fun.
Old 01-04-2005, 04:50 PM
bossind's Avatar
bossind
bossind is offline
Do any work recently to your truck? Added anything? Anything that may have shorted a wire?
Old 01-04-2005, 11:19 PM
xratedbronco's Avatar
xratedbronco
xratedbronco is offline
I just had the same problem. I installed side steps and drilled through a cable on the drivers side and didnt even know it.
rangerman321
1983 - 2012 Ranger & B-Series
09-28-2022 05:51 PM
smokeywagon
09-04-2014 09:20 PM
thehedonist
06-13-2013 07:15 AM
whatzup
1999 to 2016 Super Duty
06-30-2006 03:09 PM
whalerron
07-29-2005 10:46 PM
Quick Reply: 94 Bronco Speedometer and shift problem
