Victor "FULL" Gasket Set w/ no Exhaust
#31
Originally Posted by bigwin56f100
hey wayne,
check my gallery and look at the engine pic and you'll see the heat shield/gasket. note thaT it also shields heat fron the valve cover. the gasket and shields are all one piece.
Kevin Bigwin
Kevin Bigwin
Hey Ya'll Support our great site.
#32
Ed,
The ram horn manifolds were used on the 1957 thru 1962 tilt cab trucks C500 and C600's with a 292. Some f 600 series trucks may also have come with them.
Be carefull not to get the larger linclon Y rams as they will not fit. The manifolds you want have a straight horizontal bolt pattern (manifold to head) NOT A STAGGERED
Hope this helps,
Kevin
Hope this helps,
Kevin
#33
Thanks
Thanks Kevin That is some good info to remember.. I got wraped up in Ya'lls threads last nightand OMG I learned some thing. Ya'll wern't on here when I started and gave up on Project 57....... I never knew about Ramhorns, nor the Bigger valves in the different heads .... now all I have to do is find a thread on Hydrolic lifters...
