Reading dipstick on transmission fluid change - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 01-03-2005, 02:00 PM
GrassHopper2 GrassHopper2 is offline
GrassHopper2 is starting off with a positive reputation.
This may seem like a silly question but anyone know how high the fluid should be on the transmission dipstick when the engine is off? This is for a 2000 X 5.4 L engine 4x4. Reason I ask is because I am having a heck of time reading my dipstick with the new fluid, not dark enough in color. I can see it easily when the engine is off, it is reading a little high but with the engine in park and idle seems like the fluid is all over the place on the stick and I want to be sure I have not over filled or underfilled.
Thanks in advance.
Old 01-03-2005, 03:40 PM
neilc88's Avatar
neilc88 neilc88 is offline
neilc88 is gaining momentum as a positive member of FTE.neilc88 is gaining momentum as a positive member of FTE.
I don't think you can get a consistent reading with the engine off. That is why it has to be checked while running. If you cannot read the front side of the dipstick, look at the back side. This seems to work for me. Good luck!
Old 01-03-2005, 07:18 PM
NeilC88
Thanks for the response. I am feeling foolish having such trouble reading a dipstick. I have tried looking at both sides and looking at it in different light. I am thinking now maybe I am a little low and that is why I am having trouble seeing it, I guess I can always drain some out if I am wrong.
Old 01-03-2005, 10:16 PM
T- Squared T- Squared is offline
T- Squared is starting off with a positive reputation.
Hopper, you can try scuffing the back side of the dipstick with emory cloth or fine sandpaper. Sometimes this helps. Before checking it though, be sure and take it for a good long drive. Remember, you're heating up 17 quarts of fluid. The extra fluid should clear out of the dipstick and be easier to read also.
Old 01-05-2005, 08:17 PM
Munkey's Avatar
Munkey Munkey is offline
Munkey is gaining momentum as a positive member of FTE.
You gotta make sure the trans is fully warmed up (as suggested above w/the long drive). Your truck has to be on a fairly level surface, I've gotten wonky readings while at the gas pumps that have a slight slope away from the pump. Leave the engine running and cycle the trans from 'PARK', all the way down to '1', and back up to 'PARK', letting the trans engage in each gear.
I've never been able to get a solid marking on my trans dipstick. I always get a half-mark, or a dry spot where the fluid is marking.
Old 01-22-2005, 07:43 PM
Thanks for the input. I was finaly able to get a reliable reading by looking at where the fluid started to run from on the stick when holding the dipstick at a slight angle. A word of caution for those of you doing your own tranny fluid changes. When I was was filling mine up, i spilled some and the fluid went into the #2 plug and coil socket on the engine. Engine started to miss until I figured out what was going on and cleaned the COP and sparkplug. Scarry thing was that the engine miss felt like a tranny problem. As usual, another learning experience for me.
Old 02-28-2005, 11:19 AM
quarterhorsemom quarterhorsemom is offline
quarterhorsemom is starting off with a positive reputation.
Dont feel bad. Two tow truck drivers couldbnt get a clear reading and tranny place said ex sticks are impossible.
I am on my second tranny. it was a 125,000 mile replacement. I now baby this one. I only have 5 more payments and I am done.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
