Holley Carb with AOD Tranny/T.V. - Ford Truck Enthusiasts Forums
Old 12-20-2002, 10:35 PM
RNMCGUIRE RNMCGUIRE is offline
RNMCGUIRE is starting off with a positive reputation.
Hello, can anybody tell me the deal with the throttle valve cable hookup on an 84 F-150 351W/AOD Tranny? I just bought a Holley 4bbl carb on ebay that I plan to install on my truck. I was told that it has the ford A/T kickdown and that it will work on my truck. I am kind of confused about the throttle valve concept on this truck and wonder if I will have to buy some kind of adapter kit for the new carb. Currently, the tranny doesn't shift right. 2nd gear @ 25mph, 3rd @ 35mph, and OD @ 62mph. Honestly, I'm not even sure if all the linkage/tv is there or setup correctly because my haynes manual is very vague on the subject. All info will be greatly appreciated! Thanks!
Old 12-23-2002, 09:26 AM
essayons essayons is offline
essayons is starting off with a positive reputation.
Unfortunately, I don't have a ton of info on this,
just bad experiences.
I have a 1992 T-bird that threw 2 AOD transmissions
due to incorrect T/V adustment. I thought it was BS, but
it was confirmed by a trans rebuilder, my mechanic and my
parts guy. The problem is, unlike an old vacuum modulator
which just made it shift weird, The T/V slides the trans in
and out of O/D. If the cable is incorrectly set, you WILL burn
up the O/D and then the rest of the trans. I personally don't
know anyone who performed your mod, so I don't know how to proceed.
Just beware that maladjustment can destroy your trans in under 100
miles. I'd recommend small adjustments, drive it, and keep adjusting
until it shifts at the right shift points. The important is the O/D,
because it can screw up without you really noticing it- trust me on
that one. Hope it all works out for you. --Paul
p.s. trans for that thing is $700.00+ for rebuild.
Old 12-23-2002, 03:06 PM
Forgot to mention,
Check out Baumann Engineering. They pecialize in such
things.
Here is the link for the TV cable:
http://www.baumannengineering.com/tvlnkage.htm
--paul
Old 12-23-2002, 11:02 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
Odd - my Haynes manual is very specific on the TV cable, including the exact procedure on adjusting it. Do you have the latest revision of the manual? Mine is the last red-covered revision, but the new ones have a blue cover.
Old 12-24-2002, 12:14 AM
HD61cuin HD61cuin is offline
HD61cuin is starting off with a positive reputation.
AOD to Holley 4 barrel madmacs 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 04-27-2012 10:50 AM
AOD THROTTLE VALVE CABLE AND AUTOLITE 4100 CARB gusso 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 03-09-2010 02:51 PM
Using AOD w/ TV linkage on Holley Carb ssanto Clutch, Transmission, Differential, Axle & Transfer Case 1 07-28-2006 08:33 AM
aod kickdown kit pageparsley Clutch, Transmission, Differential, Axle & Transfer Case 1 01-30-2005 06:48 PM
Holley 4BBL with AOD Tranny? RNMCGUIRE Fuel Injection, Carburetion & Fuel System 1 01-01-2003 05:27 AM
Tags
312, 84, adapter, adjustment, aod, bird, carb, carborator, carburetor, f150, ford, holley, kickdown, prices, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
