Myth or Fact about V-8 Engines??
I was told having the 4.6L V-8 engine in my truck that these engines a long with the 5.7L V-8 engine will last longer then the V-6 engines or 4L engines de to the V-8 not having to work as hard to pull ur car or truck? Is this a myth or a fact? If You compare a v-6 to a V-8 will the v-8 last longer since it doesn't have to work as hard as the v-6 over time??
I know this is a dumb question but I wasn't sure myself..
A stock V8 will produce more torque due to increased cubic inches. Torque will allow the engine to run at lower rpm during cruise etc. Less rpm means less wear and tear to the cylinders and valve train. So in theory it should last longer. With that said, seals and other parts will break down the same as in a 4 or 6 cylinder. So the difference may not be noticeable if both were well maintained and driven the same.
Torque output does not dictate RPMs. Gearing does. My V6 van runs the same RPM as my V8 truck at 65 mph.
Although, what you guys say bears truth.
The engine with the slowest piston speed & lowest torque output should last longest, given that every thing else is equal. Slow piston speed cuts down on ring & valve train wear wear, low output reduces stress on bearings et al. Hence, diesel engines lasting so long. (Those are just part of the reason why stock diesels can go so long between rebuilds.)
A V8 with a shorter stroke than a V6, V4, I6... etc... etc... will have a higher piston speed. So, in theroy, would wear quicker.
Again, the number of cylinders does not necessarily dictate the longevity of an engine. Just ask the Cummins (I6) vs. PSD (V8) crowd!
Think you missed my point, An engine with higher torque will be given a steeper overdrive. Don't know any V6 that will cruise at 70 mph at less than 2,000 rpm as does the F150 with standard 3:55 gears.
The V6 will develop it's torque at a higer rpm. Therefore the OD gearing will not be as steep.
If the stroke on a V8 is smaller then the I4 and V6 yes the V8 will have to rev higher to achieve it's torque value. But to compare apples to apples we are talking common everyday "gas" V6's and I4's used today in similar vehicles. Most "gas" V6's and I4's used today develop their torque at higher rpms then do today's V8's. We can get into exceptions, but as a general rule, think the above is true.
Now with that said, does your van cruise at 70mph at less than 2,000 rpm?
oobical
04-06-2007 05:53 PM
