Shift Tube
Old 01-02-2005, 08:15 AM
J.O.S.'s Avatar
J.O.S.
J.O.S. is offline
Shift Tube
Need help. How do I remove the shift tube to replace it with a new one?
1967 F100 SWB 352 3 Speed o the columm.
Thanks,
J.O.S. Shelby, N.C.
Old 01-03-2005, 01:07 PM
qman's Avatar
qman
qman is offline
You have to take the steering column out and take it apart. It's real simple and while you're in there replace or grease the bearings.
Old 01-04-2005, 02:19 PM
digitalrancher's Avatar
digitalrancher
digitalrancher is offline
I agree with "qman". It's not too dificult to remove the steering column, but it does require patience and attention if you are new to this. I have a 72 F-100 (bought it about 9 mos ago) and recently had to replace my column for the same reason. It'll take much longer to get it out than you think, but goes back much easier as well. Good luck.
Old 01-05-2005, 01:05 PM
J.O.S.'s Avatar
J.O.S.
J.O.S. is offline
Thank you very much.
Old 01-27-2005, 08:04 AM
J.O.S.'s Avatar
J.O.S.
J.O.S. is offline
I have replaced the shifting tube in my 1967 F100, easy to do the only part that give my trouble was not knowing the direction to take out the old tube (push it out from the bottom to the top) be sure to check the bearing as indicated by qman.
Thank you guys
Old 01-27-2005, 12:51 PM
qman's Avatar
qman
qman is offline
Glad we could help. Steers real nice now doesn't it?
Old 01-27-2005, 01:20 PM
J.O.S.'s Avatar
J.O.S.
J.O.S. is offline
Like a BABY.
cope1972
01-02-2021 07:30 AM
dalberti
Electrical Systems/Wiring
04-04-2016 06:58 PM
Jos92
General Diesel Discussion
04-10-2015 11:10 AM
J.O.S.
17
02-08-2005 07:22 AM
Quick Reply: Shift Tube
