One Piece Window Glass Installation - Ford Truck Enthusiasts Forums
Old 01-01-2005, 09:10 PM
bhowe2 bhowe2 is offline
bhowe2 is starting off with a positive reputation.
I am considering installing a one piece window in my 1955 F-100. I see several kits ranging from $390-540. Some indicate "with corner cover" What does this mean? Does anyone have experience or recommendation as to kit to use or one to stay away from. Do these kits work well?
Brian
Old 01-02-2005, 05:34 PM
jniolon's Avatar
jniolon jniolon is online now
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
one piece window kits
Brian,
no one will answer you, huh bunky ??
well...I'll tell you what I know...
the earlier 'ventless' window kits replaced the side window with a wider glass but didn't completely do away with the vent... instead it replaced it with a plastic insert that filled in the little vee at the bottom of the door
picture shamelessly scarfed from Kenneths site..
the reason they do this is the hinge pocket is in the way...and it was easy...
next came the kit (and I don't remember who made it...but some of the guys on this board have used it... and the vendor was at the Supernationals for the past few years...
anyway
it required modifying the hinge pocket, and doing some slicing from the window slot to allow the full width window to slide up... I looked into it but since my body work was complete on the doors it was too much work for me...besides... I miss the vent windows and the breeze they let in....
hope that helps, you might do a search on "ventless windows" OR check with some of the vendors
later
john
Old 01-02-2005, 06:20 PM
54 gene 54 gene is offline
54 gene is starting off with a positive reputation.
Check out Midfifty.com they sell both hope it will help you out.
Old 01-03-2005, 05:02 AM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
I purchased the one piece tinted door glass kit for my 51 from John's-F-Fun Hundreds in Buena Park California for $320.00. for both doors
Old 01-03-2005, 06:49 AM
nixer nixer is offline
nixer is starting off with a positive reputation.
i see that nolimit has both the filler piece version and the full glass version.
just my .02
Old 01-03-2005, 09:08 AM
don1077 don1077 is offline
don1077 is starting off with a positive reputation.
I installed the one piece windows with the corner pieces, Got them from mid
50's. I removed a section of top inner door panel cause the wipers bound the new glass. I replaced that missing section with some vynil to hold the wiper.
In all I'm happy with the results. I 6'2 with long arms and can now better assume that "cool " driving attitude with my arm streached out on the window frame. By the way there is an article in this months c/c trucks about 1 pc. power windows.
Old 01-03-2005, 03:54 PM
Jet Jock Jet Jock is offline
Jet Jock is starting off with a positive reputation.
I installed a kit (for a F-1) from Vintage Glass in Georgia. A little slow on delivery but a very nice kit at a better buy than some of the West Coast shops.
Jet Jock
"I drive a 'girly' 302 because, when I want to go fast, I go to work"
Old 01-03-2005, 11:57 PM
CIAF's Avatar
CIAF CIAF is offline
CIAF is starting off with a positive reputation.
J Jock, links ???? phone numbers ??? City ???? Quality ??? ease of install ??
smooth operating ??? Thanks
Old 01-04-2005, 05:31 PM
El Cabron
The quality is good, the ease of install is about a 6 or 7 (on my scale). We cut 3 holes in the inside door panel two for the center mounts and one for the bottom of the fron channel. I like the kit.
www.vintageglass.com
Jet Jock
Old 01-04-2005, 08:15 PM
CIAF's Avatar
J Jock, thanx . I think I will try these guys on for 1 pc side and the P/W kit. This lead comes just in time as my cab and doors are ready for paint and I am ready to order kits. You were right, the prices are a good value compared to the "Big Ad" guys in the truck mags. Thanks again.
Old 01-06-2005, 12:45 AM
60panel 60panel is offline
60panel is starting off with a positive reputation.
Has anyone done one piece windows in 57-60 ford trucks. I think it can be done. I am seeing 55-57 chevy trucks with one piece windows and they have the forward cant on the front door post. I would love to hear if someone has done this. I would like to have a spare door to experiment on.
Single Door Glass for 1948-52 F1 AmeriKen 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 03-21-2015 12:27 PM
One Piece Window Kit? Schmitty 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 01-11-2015 07:39 AM
F100 Central One Piece Window Kit - Do not buy!!! Perry55 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-25-2014 01:55 PM
Installing Power Door locks help Gibby55 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 06-10-2013 04:54 PM
Vent window elimination kit 58shortbed 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 09-11-2004 11:39 PM
Tags
54, 56, 57, door, f100, ffun, ford, glass, hundreds, install, installing, johns, kit, piece, truck, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
