Glass to Metal Frame Seal on Vent Window
Old 01-01-2005, 04:29 PM
Christopher2's Avatar
Christopher2
Christopher2 is offline
Exclamation Glass to Metal Frame Seal on Vent Window
What is the material that holds the glass in the metal frame of the vent window? It appears to be about .050" thick is this the glass setting tape I have seen in catalogs?
I am not looking for the piece of rubber that goes on the metal frame that seals when the vent window is closed or the 12" long piece that is connected to the back channel of the roll up window that seals on the back of the vent window when it is closed.
Old 01-01-2005, 05:27 PM
merc546's Avatar
merc546
merc546 is offline
Yep it sure is.
Chuck
Old 01-01-2005, 08:30 PM
Randy Jack's Avatar
Randy Jack
Randy Jack is offline
I recently had my vent windows redone by a local glass shop. $20 per side to remove and install them and I waited while he did it. The seal material was something they had on hand. It appears to be a composite rubber material - black with grey flecks in it.
Old 01-01-2005, 08:33 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,610 Likes on 1,454 Posts
When I had my vent glass replaced the glas shop just used a clear sealant/adhesive, caulk type material that they use in all their applications.
abe
Old 01-02-2005, 08:45 AM
Christopher2
I was going to use a Silicone adhesive also. I am not sure that the vent window would seal correctly on the 1950 without the extra space being taken up by the material around the window. The glass could actual be put in crooked without the .050" of material around the edges.
Old 01-02-2005, 12:35 PM
Randy Jack's Avatar
Randy Jack
Chris - Abe has a good method, but like you, I would worry about centering the glass. I would also be concerned about cleaning up the silicone squeeze-out.
Try a local glass shop to see if they don't carry the stock packing. I didn't think to ask my guy what the stuff was, but he stocked it apparently for many applications. This glass guy has done a lot of street rods and restos, though, so you might have to look around for it.
I checked my catalog file and while many suppliers offer the vent glass, none reference this seal/packing. We're on our own here.
Old 01-02-2005, 02:07 PM
1949fordf3's Avatar
1949fordf3
1949fordf3 is offline
Glass Setting Tape
My Glass Shop wanted $65 to set my Vent Window Glass for the 50 F1. I bought the tape from Early Ford V8 Sales in Ballston Spa, NY (earlyford.com part number B-37193-D) for $9.00 and set them myself. They need to be nice and warm to set good, so I set them out in the sun for an hour and then the glass pressed in OK. I have enough tape left over , so if you want it, send me an e:mail with your address and you can have it. Happy New Year!! Newt
Old 01-02-2005, 02:16 PM
Christopher2
I am going to try my local glass shop first to see if I can get it from them tommorrow if not I will send you an email.
CUINAK
09-27-2019 10:48 AM
Nash Bridges
60
05-12-2012 02:15 PM
Solaratrd
02-01-2012 11:12 PM
cjvail
1947 and Older Ford Trucks
07-10-2004 07:47 PM
Quick Reply: Glass to Metal Frame Seal on Vent Window
