68' F100 4x4 flathead? - Ford Truck Enthusiasts Forums
Old 01-01-2005, 11:22 AM
liv3wire liv3wire is offline
liv3wire is starting off with a positive reputation.
I have a 1968 F100 4x4. Is it possible to put a flathead in it?
I heard an old flatty years ago and never seen or heard anything like it since.
Would be awesome to put one in!
If so what to look for in motor and trans?
Old 01-01-2005, 12:50 PM
mtflat mtflat is online now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Possible, but its only 100 hp and a '68 4x4 is heavy. You could enjoy the sound, but you won't like the performance. What trans do you have currently?
What do you look for? First would be to find a crack free flathead. That's sorta like the needle in the haystack. Be careful of ebay - lots of junk passes there.
Old 01-01-2005, 01:01 PM
c6 tranny
and the flatty just wouldnt or couldnt have the power i wanted?
i'm currently taking a 360 and converting it to a 390, with hopes of about 4 to 450 horse power
Old 01-01-2005, 09:09 PM
How fast do you want to go? Next question is how deep are your pockets? Flatheads to rebuild stock are expensive. You can get close to 200 hp fairly reasonable $$-wise, but more than that will cost you. Headers, dual intake/carbs, cam, high compression heads, etc. - the usual hotrod upgrades can be had for 1-2 grand. Beyond that it gets expensive.
The link below will let you know what they're capable of.
http://www.flatfire.com./
Forget the C6 - it eats about 65 hp just to get the wheels moving. C4 is better - check out Flat-O products. They have the adaptors to make the connections.
Old 01-01-2005, 11:38 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Here is what you have to do to get a 390 to give you 450 horse:
http://www.hotrod.com/webonly_january/
Seriously, what do you think you'd have to do to the flathead to make that power?
Flatheads are sweet sounding good running motors. I fondly remember the sound of the one in the old man's F6, with a 4 speed and 2 speed rear axle. All the way up to, gasp, 60 MPH.
Leave the flatty to a proper application.....
IMO, of course.....
Old 01-02-2005, 07:59 AM
captchas captchas is offline
Guest
captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.
i have to agree here a flatie belongs in something 53 and older,maybe a 49 to 53 into some much older at the worse. has to be a flatie into a ford for me.immo
the sound well a flatie has it's very own sweet to this old timer
power no they never realie had it , there where a very lot of speed parts made but they are hard to find now.some company even made a set of ohv heads for them. good luck.
Old 01-17-2005, 10:30 AM
SteV8e's Avatar
SteV8e SteV8e is offline
SteV8e is starting off with a positive reputation.
If you like the flathead, go for it. I recommend you consider a T5 transmission out of an S-10, Mustang, Camaro, etc., depending on the shifter position you need. There are several threads on this topic that you can find on this forum. Cornhusker makes a kit for this and there may be others. You can also make your own block to transmission adapter from 1" thick aluminum.
300 I6 or a flathead 8 in a 1960 4x4 Caveman2851 1957 - 1960 F100 & Larger F-Series Trucks 10 07-18-2014 11:05 AM
1953 f100 flathead front motor plate 0ld 53 4 me 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 12-09-2013 09:51 PM
Dies in gear 85Hp-Flathead Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 10-22-2008 01:15 AM
Flathead V8 to C4? anotherF150 Flathead V8 & Flathead 6 3 03-22-2004 06:19 PM
How to identify a flathead? 51dueller Flathead V8 & Flathead 6 7 10-05-2002 01:06 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1, 4450, 4x4, 68, adapter, f100, f260, flathead, ford, hotrod, make, model, t5, thick, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
