Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-31-2004, 05:23 PM
NoAZ'68 NoAZ'68 is offline
NoAZ'68 is starting off with a positive reputation.
351w roller block vs. non build-up...
Hello, I have a 351w HO motor that currently resides iin my EB. The motor needs a complete rebuild, and the crank is scored fairly badly. I want to rebuild this beast, but I also want a roller cam. I have access to a '96 351w block w/ crank and pistons that needs to be rebuilt for about $200, but the crank seems to be o.k.
Question: is it better to go with the roller block, or is it just as easy to tap and drill my block for the roller cam conversion. I am interested in longevity and good power.
Thanks
  #2 (permalink)
Old 12-31-2004, 06:24 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE. MustangGT221 has a good reputation on FTE. MustangGT221 has a good reputation on FTE.
Since you want the hydraulic roller stuff anyway...it's better to use the roller block. My 393 is an older 70s 351 non-roller block, but I've got hydraulic roller lifters installed. It costs extra and it's easier to just use a roller block if ya want rollers anyway.
__________________
Justin-FTE Moderator
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
04' Explorer Limited 4.6L
94' Cobra - 1 of 123 made, only 30k miles
87-96 Forum
  #3 (permalink)
Old 12-31-2004, 06:50 PM
Thanks for the reply. I thought about just using my block and going with the roller lifters and reduced base circle cam, but since $$$ are an issue I figure that if the crank in the other block is good, I would be ahead of the game. My original plans were for the F.I. 393 or 408 stroker, but rust repair and drivetrain will be taking up my extra $$$.
  #4 (permalink)
Old 12-31-2004, 11:44 PM
gamehunter gamehunter is offline
gamehunter is starting off with a positive reputation.
If you go with a non-roller block, and convert it to roller, you have to use a special retrofit cam with a reduced base circle. A regular roller cam will not work. Tradoff: earlier castings have higher nickle content, especially 69-mid 70's, and are a good deal stronger in high HP situations.
__________________
'90 F-150 lariat 4x4 302 M5OD 3.55
Finally complete: 351W EFI swap (a few mods)
  #5 (permalink)
Old 01-01-2005, 08:50 AM
You don't HAVE to do it that way, my motor has a roller cam and hydro lifters even though it's an older block, they make special lifters that'll work...
__________________
87-96 Forum
  #6 (permalink)
Old 01-01-2005, 11:17 PM
Well, I havn't specifically heard about these lifters you talk about. I just don't see how you could change lifter style to allow running regular roller cams. The lifter bores on non-roller blocks are considerably shorter for obvious reasons. Could you produce a link to such a piece? Maybe I have just been sleeping all these years!
__________________
  #7 (permalink)
Old 01-02-2005, 10:32 AM
They have them everywhere, in the FMS catalog, jegs/summit have them.....they're a linked roller lifter that fits in a non-roller block, they make them for chevy's too. I don't know exactly if mine are the linked ones or not, but mine are a roller lifter and they're hydraulic, and they're in a non-roller block. I didn't install them, CHP did when they sent me the shortblock. You've got me curious now, I'm gonna look closer at the lifter before I put the intake on, I don't think they're linked but they may be.
__________________
87-96 Forum
  #8 (permalink)
Old 01-02-2005, 10:48 AM
jwtaylor jwtaylor is offline
jwtaylor is starting off with a positive reputation.
I agree with mustanggt221, one example CRA-36532-16
they even make roller cams with distributor gear rings compatible with cast iron (non roller) distributor gears
The retrofit lifters aren't cheap though ($300-$400 +/-), if you can get the F4TE block for $200 and its in otherwise good shape then you'd be saving yourself some money.
Tags
302 , 351 , 351w , block , build , buildup , cam , conversion , convert , distributor , ford , nonroller , roller , truck , years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
