Big tires, can the inline six handle it, also what set is best??
Old 12-30-2004, 03:20 PM
mikedogg7's Avatar
mikedogg7
mikedogg7 is offline
Hey me again, I got a nice set of 15 inch aluminum rims from a friend, but there are some old tired tires on it, they measure 31 by 10.5 R15. So can my 1984 Ford F 150 2WD inline six with 124,000 original Ks. Yea and i know that it is a 2wd but i like the rims. someone reply and thanks
Old 12-30-2004, 04:25 PM
bigreave's Avatar
bigreave
bigreave is offline
yeah it will turn them real easy my 85 has 33 12.50 no pob
Old 12-30-2004, 10:10 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
My '85 turns 31 10.50s thru the SMOD 4 speed and 3.50s. A little doggy off the line, ok on the highway.
You might not want to run them tires if they are really old--they get hard and slippery. Do a few burnouts and then get some new sneakers for the winter.
Old 12-30-2004, 10:23 PM
74F250's Avatar
74F250
74F250 is offline
31's shouldn't even be an issue for your truck....might even get a little more top speed off of it. I run 35's with the stock gearing, a little tall but i still run 2k rpm at 58mph
Old 12-30-2004, 11:13 PM
Twilight Child's Avatar
Twilight Child
Twilight Child is offline
i have a m50d with same setup as 85e150sixmtod, 30.5s X 10.5 3.5 LS. Can burn in first or second + reverse.
Old 12-31-2004, 12:19 AM
fordtradition's Avatar
fordtradition
fordtradition is offline
yeah, it can handle it. I have the same size tires on my 95. gives the truck great ground clearance with no lift. true, take off is a little slower, but 300's aren't built for speed anyway. the larger tires should improve your gas milage a little as well. the 31's fill the wheel well nicely.
Old 12-31-2004, 10:28 PM
wolfe1104's Avatar
wolfe1104
wolfe1104 is offline
I HAVE 35 x 12.50 on my 95 which has 130 k miles on it and the 300 handles it fine. Im unsure of the gears but i know that they're higher. But I have no problem. It takes a little longer to get up to speed but other wise no problems.
Old 01-01-2005, 05:24 PM
mikedogg7's Avatar
mikedogg7
alright thanks guys
Old 01-03-2005, 12:32 PM
papaw123's Avatar
papaw123
papaw123 is offline
I'm running P285/75R16 (33") on my '91 F150 4x4 with 3.09 stock gearing but with the taller tires, the ratio is, in effect, around 2.70. Pretty doggy. I plan on a change to 3.73. The six handles pretty good even with that ratio.
Old 01-03-2005, 01:09 PM
hedgeapple's Avatar
hedgeapple
hedgeapple is offline
My '81 (see signature) had 31x10.5s on 16.5x8.25 wheels when I bought it.The fronts scrubbed a lot in turns. The tires were worn to 30" diameter. Mounted a set of 235/85R16 retreads, 32" diameter, on stock 16x6.5 rims. The scrubbing disappeared, even before re-alignment, but accelleration really suffered and passing power is now nil.
Old 01-03-2005, 03:01 PM
optikal illushun's Avatar
optikal illushun
optikal illushun is offline
u can turn any size tire u want with the proper gearing...
Old 01-04-2005, 01:23 PM
BabeTheBlueOx's Avatar
BabeTheBlueOx
BabeTheBlueOx is offline
I agree with Optikal Illushun, It's all in the gearing as to how big a tire you want to run with a 300, I have a set of 46 inch Claws on my '95, I got rid of the Mazda five speed and put in a C-6, and I'm running 6;17 gears in my '79 one ton axles under it, She'll still turn'em over relativly easily
Old 01-04-2005, 02:11 PM
optikal illushun
jeez 46" claws...thats a whole lotta tire! arent the like 20" wide and weight 130lbs each?
Old 01-04-2005, 04:15 PM
bigwally's Avatar
bigwally
bigwally is offline
Will it Handle It
I had an 84 with inline 6 and 3 spd w/od manual tranny. I put 31" tires on it. The engine handled it OK but it tore up the tranny and top speed was 70. Also, the speedo and odometer will be off. My odo was short 10 miles for every 100 driven!! You have to keep in mind that the big tires change your gear ratio's.
I also had to beef up the front springs to keep them from hitting the fenders. I used Airlift airbags in them.
Old 01-04-2005, 05:01 PM
BabeTheBlueOx
Yeah, there BIG'UNS allright 19.5\46\16LT and with the wheels that I had made for them they are 210 # each Tire and Wheel combo, I had MRWOFFROAD make me a set of 16x16 black steelies with one inch backspacing to set the tires out a little wider to help with the stability issue of going so big , hope to get pics up soon as soon as I can figure out this new fangled digi cam
Quick Reply: Big tires, can the inline six handle it, also what set is best??
