Ford engines built better than Toyota?
It could actually be true!
I recently performed a vacuum test on my 4.0l SOHC V-6 Ford to narow down the cause of an erratic idle problem. The vacuum test showed a steady 19 in/Hg at slow idle... normal.
To compare, I tested my 2.4l I-4 Toyota motor. Whoa! The needle was rapidly vibrating between 18-22 in/Hg at slow idle! This is way abnormal!
I had no idea that the Ford would do so much better on something like this.
Just some food for thought, but maybe Toyota's stealing of the car market is due to their PAST reliability that may not necessarily true now.
The vibrating needle was probably because its a 4 cylinder. The manifold vacuum of any 4 cylinder at idle will inherently be less steady than a 6 or 8 cylinder, because there are fewer cylinders intaking air per revolution.
I cannot see a connection between manifold vacuum and engine reliability. Put a bigger cam in and the manifold vacuum at idle will go down. Plain and simple.
It depends on the engine. I used to have a pos 84 mustang convertible with the 3.8L and throttle body injection and it was a hunk of junk.
I also owned a pair of 87 Supras. The 87-92 Supra Turbos had major headgasket problems where they would blow out under boost.
They all have their own set of problems.
Per my Haynes manual, a healthy engine should have very little fluctuation in pressure. I think 4 in/Hg is a lot for a stock motor IMO.
bunruh
11-23-2022 11:46 AM
ola1234
11-20-2016 03:12 PM
itsnotavan
36
07-31-2016 05:12 AM
JL-78
06-29-2015 08:58 AM
