power distribution box diagram
i recently battled the door ajar problem, and won the battle, but lost the war. I went to remove fuses to eliminate the light, and now the truck is acting like it isnt gettin gas. I would like to see if someone could find the diagram and possibly what fuses need to go where in that box.. any help would be appreciated
Jason
97 4.6 L
Jason
97 4.6 L
Just a question out of the blue... Does the door ajar problem appear after a rain or heavy dew/fog? If so you might want to have the window checked for leaks. Mine started out with the door ajar, then progressed to 4x4 indicator flashing and alternating with the overdrive light on the end of the gear shift lever.
Just asking it you notice this problem appearing after a rain but eventually clears itself up when the rain stops and has a chance to dry out.
hugger94
97 F150 5.4L 4x4
hugger94
97 F150 5.4L 4x4
Jason
97 4.6 L
Jason
97 4.6 L
Enjoy FTE we are happy to have you on board!~
Welcome to FTE!
Near the top of every page you'll see in the dark blue ribbon "User CP". "FAQ", etc., etc. Click on FAQ then pick a topic & click on that. Most everything is explained there.
Also, click on "User CP" & you can update your signature, etc., etc.
As you look around this site, click on everything because this site is just loaded with features & you'll be amazed at the extra info you'll find "hidden" throughout.
AL.
AL.
arkiados
11-29-2022 08:31 AM
danyl01967
07-25-2011 08:28 PM
RCrawler
02-06-2010 10:02 AM
