power distribution box diagram - Ford Truck Enthusiasts Forums
Old 12-29-2004, 10:29 PM
Jason77090 Jason77090 is offline
Jason77090 is starting off with a positive reputation.
i recently battled the door ajar problem, and won the battle, but lost the war. I went to remove fuses to eliminate the light, and now the truck is acting like it isnt gettin gas. I would like to see if someone could find the diagram and possibly what fuses need to go where in that box.. any help would be appreciated
Jason
97 4.6 L
Old 12-29-2004, 10:40 PM
hugger94 hugger94 is offline
hugger94 is starting off with a positive reputation.
Just a question out of the blue... Does the door ajar problem appear after a rain or heavy dew/fog? If so you might want to have the window checked for leaks. Mine started out with the door ajar, then progressed to 4x4 indicator flashing and alternating with the overdrive light on the end of the gear shift lever.
Just asking it you notice this problem appearing after a rain but eventually clears itself up when the rain stops and has a chance to dry out.
hugger94
97 F150 5.4L 4x4
Old 12-30-2004, 06:46 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Quote:
Jason
97 4.6 L
Welcome to the only family Ford Truck site, on the net. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old 12-30-2004, 11:28 AM
where would i go to locate that.. sorry, im new to this forum
Old 12-30-2004, 07:44 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE!
Near the top of every page you'll see in the dark blue ribbon "User CP". "FAQ", etc., etc. Click on FAQ then pick a topic & click on that. Most everything is explained there.
Also, click on "User CP" & you can update your signature, etc., etc.
As you look around this site, click on everything because this site is just loaded with features & you'll be amazed at the extra info you'll find "hidden" throughout.
AL.
Old 12-30-2004, 08:32 PM
just an update.... i switched the fuel pump relay with one that i know works.. and it still wont fire, and i replaced the fuse in the box with a new one. and it STILL wont fire... any help would be greatly appreciated
Jason
1993 F350 Power Distribution Box Diagram arkiados 1987 - 1996 F150 & Larger F-Series Trucks 3 11-16-2015 07:35 AM
Distribution Box diagram - 94 E250 danyl01967 1968-2013 Full Size Vans 2 07-25-2011 08:28 PM
Reverse Lights / Fuse question jls8177 1999 - 2003 7.3L Power Stroke Diesel 6 03-12-2010 04:34 PM
intermittent wiper wiring diagram RCrawler 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-06-2010 10:02 AM
'97 Expy power distribution box lobsterboy Electrical Systems/Wiring 5 04-11-2004 08:46 PM
Tags
1997, 1999, 94, 97, box, diagram, dist, distribution, expedition, f150, ford, locate, power, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
