Good mechanic in SLC area - Ford Truck Enthusiasts Forums
Utah Chapter Join Chapter, Leader:
Old 12-29-2004, 02:08 PM
cichosz cichosz is offline
cichosz is starting off with a positive reputation.
Hi Everyone,
I am looking for a trustworthy mechanic to do some work on my 98 explorer. Anywhere in the Salt Lake or Utah Lake valleys is good.
I failed the emmisions test - P0401, P0402, and P1401 errors! I don't want to replace the Cat if it is just a matter of an O2 sensor.
I am new to the area...
Thanks,
Jay
Old 12-29-2004, 02:46 PM
mjwhip2 mjwhip2 is offline
mjwhip2 is starting off with a positive reputation.
Welcome to FTE Jay. Sorry to hear of your troubles buy the only mech I know of who won't try to screw you over is up near Ogden. The thing that I don't understand is how can you get a P0401 (EGR flow insufficient) and P0402 (Excessive EGR flow) at the same time?
Well sorry I'm of absolutely no help. Might want to try your question up in the explorer forum.
Mike
P.S. Vote for our get together and we'll see you on the 8th.
Old 12-29-2004, 02:53 PM
Thanks -
All I know is that those are the codes on my emmisions failure print out. Do you know what P1401 signifies?
Jay
Old 12-29-2004, 04:50 PM
P1401, Differential Pressure Feedback EGR (DPFE) sensor circuit high voltage detected.
I've been doing a little research for you. Apparently a bad DPFE sensor will sometimes throw all 3 of the codes you are seeing. Maybe this could be your lucky day.
Click here Maybe this could be your problem.
Good Luck
Mike
Old 12-29-2004, 06:00 PM
CobraXP's Avatar
CobraXP CobraXP is offline
CobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to behold
DPFE sensors are simple to change.
Just out of curiosity - what engine are we talking about? I've got the factory manuals on Explorers, and will help any way you need.
And welcome to the Utah Chapter! Hope you come out on January 8th!
Old 12-30-2004, 07:32 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
Larry's Car Care in West Valley is a very reputable, honest guy. He is where I take my vehicles when there is a problem that I can't resolve on my own. He is a straight forward, no bullcrap kind of person. His son is taking over the business but he is like his dad but with a bit more tact The only problem is he is a very busy shop and sometimes it takes a couple of days to get your auto done.
Old 12-30-2004, 10:35 AM
CobraXP's Avatar
Thats good to know. Since I moved here, I had not found a shop to go to. I do most of my own work anyway, but I always like knowing of a place 'just in case'.
I actually sent my Explorer back to Georgia to have the engine replaced with the new one. I talked to all the Ford dealerships, a couple of other shops, and did not find anyone I trusted to work on my ride. Granted - I am not stock and was looking for a perofrmance place, but I think the supercharger sitting on the Explorer make a couple of the dealerships nervous...
Old 12-31-2004, 09:33 AM
I forgot to mention that for the diesel owners, Baker Diesel in Ogden is one of the best. They do mods, engine swaps, rebuilds, pump and turbo. Good bunch of guys.
For either shop that I mentioned it's best to get an appointment and have a ride home although Larrys will give you a ride within a reasonable distance.
Old 01-09-2005, 04:16 PM
Zane M Zane M is offline
Zane M is starting off with a positive reputation.
I second Larry's. Great guys, but they are busy(It took three days for them to get to emission test my '83 F250-I left it there as I expected it needed some "tweaking" to pass).
Old 01-26-2005, 10:47 AM
roozter's Avatar
roozter roozter is offline
roozter is starting off with a positive reputation.
Paul's Automotive and 4x4 in Sandy is another good family owned shop. I have taken my Jeep TJ, Ford Expedition, and when the warranty runs out, I will take my F250 6.0 to him if needed. I use him for stuff I can't or don't want to do.
Recently, he replaced my tranny and the clutch pack in the transfer case of my Expedition (more details here http://www.fordtrucks.com/forums/sho...d.php?t=326901 ). I trust him and he has been in the business a long time, don't know how many years, probably 30 or so.
He also helped me with exhaust problems and emissions on my Jeep TJ.
He is right next to Jordan Commons, 90th & State
255-7472
Old 07-29-2005, 11:41 PM
WYO92350 WYO92350 is offline
WYO92350 is starting off with a positive reputation.
Thanks to cichosz for the question. I was going to post the same one. To mistakenID, could you recommend Larry's for my '92 F350 crew cab 460 ci gas? I am in need of someone to give it a general look and any help at all. Although a big truck and relatively old, the 460 is "guttless." That's the best way to describe it. Could anyone else recommend another shop? Paul's? At least one that would do good for this year/engine combination?
Thanks,
Going slow in Wyo.
good mechanic/Shop in Salt Lake or Las Vegas area? raebear1 6.0L Power Stroke Diesel 2 09-15-2015 06:02 PM
I need a good local mechanic! jasonmartin206 Washington Chapter 29 10-10-2013 06:42 PM
Paint Shop xlrs Utah Chapter 2 07-23-2010 12:22 PM
anyone in northwest PA SBastow Pennsylvania Chapter 7 12-22-2008 10:31 AM
map Josh79 Montana Chapter 4 05-02-2005 08:49 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1999, 4x4, automotive, code, differential, dpfe, e250, egr, escape, expedition, feedback, ford, p1401, pauls, pressure, sensor, throws
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
