v10 cylinder numbers/ firing order... - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 12-29-2004, 01:20 PM
oddjobs2do's Avatar
oddjobs2do oddjobs2do is offline
oddjobs2do is starting off with a positive reputation.
Hello,
Anyone know the firing order and the cylinder numbers on a v10...it is a 200 f-350 4x4.... Also best way to remove coil and boot without damaging boot!
Thanks,
Doug
Old 12-29-2004, 02:19 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Looking at the engine. Left side bank, cylinder #1 is the closest one to you.
Count from there to the back of LH bank. #6 is first one on the right bank. #10 is the last.
Question #2. Pull straight up while twisting.
Old 12-29-2004, 03:12 PM
oddjobs2do's Avatar
firing order, coils and plugs
thanks..
I was told the firing order is 1-6-5-10-2-7-3-8-4-9 but i asked because in a regular ol distributor car they can get out of order..but i guess without a distributor...who cares since the connectors are pinned to the rail....so all i need was the cylinder numbers you gave me....i have a code...obd2 says cyl number 3 misfire and the manual (for the reader) says check wire plug and coil....or o2 sensor... weell who knows how old the plugs are but I image it cant be so screwed up to misfire..never really seen that...plug wires usually...and there really qre no wires...so i was told on here before usually a coil...ikes 10 of them to go bad.....no moisture there and I cant see it at night...so I am going to replace it I guess. What are your thoughts on this? Is there a web site or a way to diagnose plug wear (I supose besides a mechanic....where i've tried with other vehichles and get 10 different responses about what the worn plug means)
PS gas mileage seems to have dropped to an all time low...and tranny slipps a little when misfiring...plus at cruise speed with slight acceleration you can feel the truck shake...all of which I assume is a misfire in that number 3 messin with it.....just curious your take..
Thanks again,
Doug
<!-- / message -->
Old 12-30-2004, 12:06 AM
Monsta's Avatar
Sounds like the COP is bad. Luckily they are readily avialbe at reputable auto parts stores. I don't think it is a problem with the plug itself unless it is cracked or somethin'.
How many miles are on your truck?
Are they the stock plugs?
I wouldn't worry about the tranny slipping until you get the engine running right. I doubt your tranny is slipping is why.
Old 12-30-2004, 01:39 PM
oddjobs2do's Avatar
Well the truck has 113k on it I was told at 96k when i bought it had been tuned..but who knows..i should change them....probably the originals....Any idea on plug recomendations. I like the idea of fuel efficient ones..like split or bosh..they have that one with the oxy sensor and some guarantee/....but does it really matter? What of factory orig ones?
What is A COP?
Thanks
Doug
Old 01-03-2005, 05:01 PM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
Quote:
The Motorcraft Platinums are as good as any.
BTW - your above post on firing order is correct (1-6-5-10-2-7-3-8-4-9)
Quote:
What is A COP?
Thanks
Doug
Coil Over Plug.
Old 01-04-2005, 07:50 PM
oddjobs2do's Avatar
Well....1 new coil and 10 new plugs....1 plug was a platinum oem plug the rest were regular....so I put doubles back in.....but 1 cyl was missing the cap to the plug (part threads on to top).... I had a misfire there now and asgain but havn't seen it since I replaced the plug...will update yall on mileage..
By the way...anyone have problems with that whine in a custom stereo on fords? Mine has a tick and then a high pitched whine that veries with acceleration. not sure if it is a groud problem that masy be ford typical; that can be corrected....But styereo was in another vehichle no whine and other fodrs have.... Anyway..
Thanks folks,
Doug
Old 02-08-2011, 10:57 AM
ravianhannah ravianhannah is offline
ravianhannah is starting off with a positive reputation.
need a diagram of the firing order v10 engine
Old 02-08-2011, 11:42 AM
oddjobs2do's Avatar
1964 F100 Engine / Trans Verification Texas_Doug 1961 - 1966 F-100 & Larger F-Series Trucks 14 07-10-2014 12:26 PM
Doug Thorley long tubes coming back.. housedad Modular V10 (6.8l) 10 01-29-2014 01:04 PM
Doug Thorley header availability housedad Excursion - King of SUVs 1 11-08-2012 12:41 PM
99 v10 firing order? 4x4k20 Modular V10 (6.8l) 2 01-31-2006 09:58 PM
v10 cylinder numbers and firing order! oddjobs2do 1999 to 2016 Super Duty 9 12-30-2004 06:04 PM
Tags
10, 2005, 68, 68l, count, cylinder, excursion, f350, firing, ford, numbering, numbers, order, ordercylinder, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
