You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What is a wellside pickup?
If you scroll a ways down on the main forum page you'll find the Audio forum. The people in there should be able to help with your question.
__________________ Dave - FTE moderator Forum Guidelines
this space for rent
i think he means a flareside...wellside might just be the term they use down there...i have friends down there and they say that all the time..i ask them..flareside..they say..well if thats what yall call it...but yeah..the audio guys can probably help ya there...good luck..and welcome to FTE
I suppose you could call it a flareside. Metal tray and sides flared out along the top edge. Metal tailgate. They are called wellsides in NZ. Thanks will check the audio thread.
Welcome to the forum, if you are still running the solid core spark plug wires I would change them for a good insulated set. You could also be getting noise from the generator. They used to make filters to block the generator noise but I haven't seen one in years. If you have any old ford parts suppliers in your area, or an electrical repair facility they might be able to help.
Thanks, We fitted some caps to the plugs yesterday and they took away all the noise on CD at least. Would have changed the leads but could only find blue wire and I want to keep the black. We also put a filter in the wire from coil to the distributor and have a choke to put in the power supply to the radio / CD if there is any distributor noise. Good progress thanks to the various advise received. Happy New Year
Hi Yes still running the gen but this is another problem. We changed the electrics to 12V as the lights were too poor at night and also had no indicators.
Now not generating enough power as at times battery goes flat. The gen is orignial with 12V field coil.
As for the wires, sure I can find some black if I look about
Did you replace the 6V turn signal flasher and install a 12V unit ??. As for the battery drain if its reading around 13 to 15 volts on a voltmeter I would suspect there is something draining off the battery in the electrical system. Pull off the positive terminal and touch it to the post to see it you get a spark with everything turned off. If so, something in the system is shorted. Be aware though that old batteries have been known to explode if a spark is generated around them. So make sure it isn't venting fumes.
I just rembered, you can use resistor plugs with the solid wires if memory serves me right. This stuff is making me go back 30 years, way back in my mental archives. Are you running the flathead 8 in your truck. I sure would like to see some pictures of it.
Hi, I disconnect the battery when the truck is in the garage (fire risk) so it is not a leakage issue. I think the rewound generator is not developing sufficient power and the speed it is turning at. An alternator would fix it. The motor is '36 flathead. The '36 motors have insert style main bearings and a little thicker as opposed to the earlier V8 motors which had about 2.0" mains and they were poured mains as well
I know an alternator would fix it however I would also think that the 12 volt generator
and regulator from a 56 or later Ford should work as well. Those generators were
nearly the same size as the old 6volts. I would think the armature and field coils
would bolt into the generator housing of a 39 or later flat head. They kept the 12
volt battery up back then (1956 to 60) should do it now.
