Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-28-2004, 12:49 PM
fdlucky fdlucky is offline
Garage is empty, add now
fdlucky is starting off with a positive reputation.
1997 4wd 4.6 f150 Clutch fan removal
I know this topic has been exhausted; however, I cannot find anything related to my specific truck. I need to find out what kind of tools I need and which way the nut turns and any helpful tips.
fficeffice" />>>
Thanks in advance, Chris
  #2 (permalink)
Old 12-29-2004, 09:27 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
I believe that it is reverse thread and AutoZone rents the removal tool for free.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 12-30-2004, 12:18 AM
97Centurion's Avatar
97Centurion 97Centurion is offline
Rub my Belly
97Centurion is gaining momentum as a positive member of FTE.
I used Channel locs to grip the smaller bolts on the pulley and a big cresent on the fan nut. Tapped the cresent a few times with a big hammer to break it loose. Worked real good. Saved me a couple of trips to the parts store to get and return the tool.
__________________
2000 f150 (4.2 needed)
1997 f150 4X4
1989 f350 4X4
1988 Bronco II (Mall Krawler)
  #4 (permalink)
Old 12-30-2004, 05:33 AM
Ted98 Ted98 is offline
Ted98 is starting off with a positive reputation.
If you have some pipe or something similar laying around, you could make your own fan removal tool in about 15 minutes. You can take a look at the one I made here:
Fan removal tool
__________________
1998 F-150 XLT, Ext Cab, 4.6/auto
My Modifications
  #5 (permalink)
Old 12-31-2004, 11:30 AM
CrownVicRickey CrownVicRickey is offline
CrownVicRickey is starting off with a positive reputation.
Thats a way to get the job done Ted,pretty cool.
Tags
1997, 1998, 2000, 42, 46, 46l, 98, clutch, f150, fan, ford, nut, removal, remove, thread, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
